Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 2nd November 2012, 08:39 AM   #821
MR OHM 1970 is offline MR OHM 1970  Canada
Originally Posted by dennismiller55 View Post
I am looking to add a low distortion audio sig gen to my bench. I have been watching eBay for good deals. Any worth bidding soon rise above my budget.
Anyway, I starting looking into a DIY Signal Generator. My research turned this up. Low-distortion Audio-range Oscillator
Anyone ever build this? Sounds good but is it? There is no build tips or PCB layout. Just a diagram and parts list.
This author has a book of all his circuit designs but comes at a steep price. However, my local library has a copy and I will pick it up sometime this week.
Old 2nd November 2012, 03:40 PM   #822
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
No filtering at all in the level detector !??!
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 2nd November 2012, 04:14 PM   #823
vicnic is offline vicnic  Latvia
Yes , it is near of a truth. I am also thinking about this. Properly level of unfiltered full wave detector signal, when injected in JFET gate, may help to reduce 3rd.
Victor
Old 2nd November 2012, 05:26 PM   #824
Samuel Groner is offline Samuel Groner  Switzerland
No filtering at all in the level detector!??!
The time constant of the LDR provides a bit of filtering, and (if I did look at it correctly in the few seconds) the filter topology has an elliptic response, which will notch out the dominant harmonic (probably the 3rd).
Samuel
Old 2nd November 2012, 05:42 PM   #825
EssB is offline EssB  United Kingdom
You do realise you're commenting on the very first post of this thread ?
'Mr Ohm 1970' just quoted it without comment.
Old 2nd November 2012, 05:50 PM   #826
Sorry I missed that, but now more to think about.
Old 2nd November 2012, 09:52 PM   #827
coluke is offline coluke  Italy
You're right (as usual ) - with the 3rd notched out by the output buffer, adding a simmetry trim to the detector can help to reduce quite a bit the 2nd (which is probably mostly due to ripple injection). This way you can get very fast settling and reasonably low THD (but poor flatness and long term stability). All in all, it's a very simple and clever topology.
L.
Old 3rd November 2012, 06:22 PM   #828
PChi is offline PChi  United Kingdom
The Roger Rosens phase shifting Oscillator is clever but I am unsure how accurate the potentiometer matching needs to be for the distortion cancellation to help. The original Wireless World article states that the distortion was measured using 1 % tolerance resistors.
Another variation on the Wien bridge is described at Injection-lock a Wien-bridge oscillator | EDN
Old 5th November 2012, 03:30 PM   #829
Interesting he quotes basicly amplifier limited THD (<120dB) with an ordinary one amplifier circuit and Christmas tree lamp.
I have never been able to observe this but I will try. I wonder if the color matters
Old 5th November 2012, 04:34 PM   #830
1audio is offline 1audio  United States
Maybe the LT1468 has exceptional common mode rejection?
Demian Martin
Product Design Services
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
