Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 29th October 2012, 10:51 AM   #811
Samuel Groner is offline Samuel Groner  Switzerland
Those seem to be exceptional results.
You can get every sensible variable gain element to show essentially arbitrary low distortion by reducing the signal level across it--at the cost of higher noise. As Bob mentioned, we need a figure of merit for the multiplier which catches this tradeoff (I'm thinking about it).
Samuel
Old 29th October 2012, 11:53 AM   #812
KSTR is offline KSTR  Germany
KSTR's Avatar
Wouldn't using two JFETs in a differential fashion be a way to reduce remaining nonlinearity of Rds vs Vds? I mean, one JFET as is on the input side of the summing junction and another matched one coming from the output, each with their series resistors. Then feeding the second one a copy of the control voltage (with additional DC bias) so that the Rds changes do work in "push-pull". Compressing/Expanding distortion vs signal would pretty much cancel out, only the difference of the Rds vs Vds nonlinearities would be effective. Also, for freqs above tuning the CV could be injected in opposite polarity (with an 1st order allpass phase shifter) so that high frequency CV ripple and noise would change both Rds' almost in phase, producing little effect on the total gain.
Just a few thoughts... well, another one : Would an expansion of the amplitude detector as shown in the EDN article to four quadrants (with 90deg phase shifters) produce any benefits? I could see faster settling as well as less and higher freq ripple of the detector output. I simmed this already and it's looking good and has not too much circuit overhead.
Old 29th October 2012, 03:24 PM   #813
vicnic is offline vicnic  Latvia
Properly built JFET VCR can be reduced to simplified schematic and it is absolutely symmetrical:
In my opinion, differential fashion is not needed, cause this fashion reduce only nonsymmetry. In the other hand, when we use two or more JFET VCRs in series, AC gain drops in every JFET and this is a way for to reduce distortions. But, I do not know at this time, which way is better: more than one JFET in series, or simple signal amplification from one JFET. This situation must be analyzed from different courses: noise, easy to bulid, cost...
Victor
Old 29th October 2012, 04:42 PM   #814
Bob Cordell is offline Bob Cordell  United States
Victor
I chose the 4091 JFET for my original oscillator based on high threshold and low Vds_on. This seems to keep the FOM high.
If one is using optimized drain feedback to the gate, this tends to kill the second harmonic distortion, leaving only 3rd, which would seem to be about what using two JFETs differentially would do.
BTW, I believe I originally saw the JFET AGC element with gate feedback on an HP oscillator. I don't remember the model or when it was designed, but I saw the schematic around 1970.
I used to devour schematics in the user manuals of HP test equipment at the time where I worked (BTL).
Bob
Old 29th October 2012, 07:08 PM   #815
Figure with noise vs. Vc of post #797 fixed.
BTW, Bob, could you post a graph of multiplier control voltage vs. frequency for your oscillator? This would be interesting to determine the necessary multiplier authority.
I've just quickly checked this with my current prototype oscillator, and the control voltage from 10 Hz to 100 kHz was below +-200 mV (multiplier scaling factor 0.05, multiplier decoupling 10x). So it looks like that, for sufficient leveling authority alone, a multiplier authority of 5m should be well sufficient for a carefully design SVF oscillator. The tradeoff is mostly with respect to settling time.
Would still be interested to see this data for the Cordell oscillator, if anyone has time!
Samuel
Old 29th October 2012, 08:24 PM   #816
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Wouldn't using two JFETs in a differential fashion be a way to reduce remaining nonlinearity of Rds vs Vds? .
I've tried this and there was no improvement over the single FET. Paralleling FET's to have lower Rdon for the same Vp might help. If you read part two of my Linear Audio article you will find a hint on how to make Victor's idealized VCR exactly, floating and completely isolated from the control voltage. I will draw it up tonight.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 30th October 2012, 04:57 PM   #817
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
SW -- Where are you getting all this free time... retired, yet? is every day, Saturday yet?
Old 30th October 2012, 09:10 PM   #818
I took vacation for my niece's wedding and the storm intervened. So I have some peace to work on things that would not get done while I watch all 10 Jason movies.
Old 30th October 2012, 09:19 PM   #819
Here's my idea. The photovoltaic MOSFET driver generates a small isolated current with up to 8V compliance. You just force this current into a large resistor to control the gate voltage of the VCR. The RC can be at a very low frequency rather easily. I envision a second control channel could be used to cancel the thirds, thinking out loud right now.
Old 1st November 2012, 08:47 PM   #820
PChi is offline PChi  United Kingdom
That floating VCR controlled by a Photovoltaic MOSFET driver is rather clever. The isolated control opens up some possibilties.
I think that it is similar in function to the Photo FET Optocouplers like the Fairchild H11F1M but lower distortion.
I am messing around with ideas to meet Samual Groner's reasonable and realistic design goal for a very good DIY oscillator. Progress is slow though because I am back at work unfortunately (bad for my sanity but good for the bank balance).
There are some other parameters to consider.
Output impedance. I prefer relatively low, < 100 ohms, it's always possible to add resistance externally.
Single ended or differential output, semi or true differential. I think that floating single ended is good enough for normal use.
DC or AC coupled. I prefer AC coupling.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright ©1999-2017 diyAudio
