Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 19th October 2012, 03:53 PM   #741
KSTR is offline KSTR  Germany
KSTR's Avatar
looks like Samuel was right and the shown results were unreal in terms of absolute levels. The synced averaging and the AP graphing methods are to be taken with a grain of salt (and there are still some real and annoying bugs in the control software), especially for less experienced operators like me.
==> Forget the previous plot I posted in #730.
I measured again, now with traditional spectrum averaging (128x) and results are way more realistic now. The differences between the DUTs, though, remain fairly constant.
Two pcs. of Viktors' 1kHz Osc were tested, I see a slight increase of LF noise vs AP Genmon and the SG505 but the harmonic purity is outstanding and seems to be consistent.
I also looked at settling after a level change, at high level settings it settles quite fast while a the low end (at 300mVrms) it bounces up and down a little for some seconds.
File Type: gif AP_GENMON vs SG505 vs 2xViktors @ 1kHz, 2.7Vrms.gif (33.0 KB, 345 views)
Old 19th October 2012, 04:15 PM   #742
Samuel Groner is offline Samuel Groner  Switzerland
Thanks very much for revising the measurements--that looks valid now!
The exact performance of the SYS-2722 depends a bit on the age, as later units have certain improved subcircuits. The one I'm using has around -135 dB (analyzer) and probably -140 dB (generator--measured with passive notch filter) 2nd and 3rd harmonic residual at 1 kHz.
So in your plot the distortion for Victor's oscillator could well be from the analyzer.
Samuel
PS: Yes, the synced average mode is tricky. Hardly ever use it therfore.
Old 19th October 2012, 04:19 PM   #743
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
I concur with KSTR, I got very similar results with two units.
Old 19th October 2012, 05:03 PM   #744
coluke is offline coluke  Italy
It seems that in the previous plot there was no actual signal to sync on both for Victor's and AP's internal generator (or signal level was by far too low to get a stable sync) - I must admit the first plot was almost frightening
L.
Old 19th October 2012, 05:38 PM   #745
KSTR's Avatar
Follow up with the 10kHz version.
The AP genmon trace again has higher 2nd and 3rd, above that it's in the noise.
Viktors' is better in 2nd and 3rd harmonic but some 4th is visible too.
File Type: gif AP_GENMON vs SG505 vs Viktors @ 10kHz, 2.7Vrms.gif (34.6 KB, 332 views)
Old 19th October 2012, 05:39 PM   #746
1audio is offline 1audio  United States
In my experience long averaging (5,000,000 point 10 averages) even crystal controlled sources can drift enough to degrade the measurements. You can see the harmonics moving from bin to bin with successive measurements.
Is the AP oscillator stabilized (disciplined)? It shows less close in phase noise than Victors.
Demian Martin
Product Design Services
Old 19th October 2012, 05:43 PM   #747
KSTR's Avatar
Our AP is about two years old, is that late enough?
Old 19th October 2012, 05:50 PM   #748
Yeah - I was wondering about Victor's phase noise and THD+N. A full spectrum comparison betweem AP's and Victor's would be interesting.
L.
Old 19th October 2012, 08:33 PM   #749
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
I quickly measured distortion of a small (10r cold resistance) lamp I had around (NOS replacement for Tek 7k scopes) and I've not been able to find any voltage coefficient effects. With 0 dBu across the lamp, distortion (pure 3rd) was -100 dB at 5 kHz. This falls at exactly 20 dB/decade, e.g. at 500 Hz I measured -80 dB. No flattening out at high frequencies was detectable--above the audio band distortion drops below the SYS-2722 residual.
So far it looks to me that all I've seen is pure thermal stuff. It's surprising at what high frequencies one still sees them. Perhaps there are lamps with different behaviour. I'll check if I find another one to measure.
Samuel
Well it was a long time ago, I remember -90dB at 10kHz and got the same THD with any op-amp. Maybe I convinced myself that that was all there was to it. I first saw this stuff in the 60's in an obscure text that used this oscillator to demonstrate the use of Volterra analysis.
I do know the non-linearity only stabilization works but have not exhaustively studied all the details. In thinking about the lightbulb, there still is in a way two effects the average power setting the resistance and the residual distortion at frequency. It might not matter that they are both thermally induced.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 19th October 2012, 09:33 PM   #750
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
I repeated my measurements of Victor's oscillator with notch filter, to attempt to clean up some of the noise I was getting previously from a sloppy test jig. Pretty impressive results - All I could detect with 1.76V output was the 2nd at -139dB below fundamental, and that's barely detectable. This is 0.000011%, that's four zeroes.
During amplifier testing I noticed the oscillator does not care to be loaded down with your circuit, so I put this signal into Pete Millet's soundcard interface, which has a gain of 2, and balanced line driver output.
Then I get 2nd at -122dB below fund, and 3rd at -131dB below fund. That's about 7 times as much distortion, but still quite usable for testing amps and preamps.
I can provide calculations if anyone questions my numbers, knowing the notch filter gains the 2nd by 31dB and the 3rd by 35dB.
Jensen transformer should be coming this afternoon, so I will get some readings to compare.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
