Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 24th September 2017, 05:32 PM   #6971
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
The particular model I ordered looks useable. However, its values and topology is also very useable if I need to make it even better. Might put in alum case.
The low-pass passive is not flexible with freq. But, I can truly get to the noise floor of -160dBv with the 725D and QA401 then.... no extraneous freqs showing. Just the DUT.
There is also a new gen put up in forum using 5534 with filtered output opamps as I suggested which in SIM looks great.
I would like to see that active filter improved (lower noise) and made more flexible for use with any generator at other freqs. Last year I showed a proof of concept using commercial filter (miniDSP) on a digital gen and how it really cleaned up a 16 bit gen. So, this needs more tuning and time on development to get its full potential realized.
But an active circuit with cap filter in fb path to also reduce the opamp thd which I also suggested and results are very interesting. If we cant come up with distortion cancelling method, this may be the next best solution. It also takes a burdon off the gen to be ultra low thd. Thus simplifying and lowering the gen cost.
I am taking off to Asia home as winter here is setting in... be away for 4 months. Today is a steak BBQ send off with family. But, I'll be Here still.
THx-RNMarsh
Old 24th September 2017, 06:29 PM   #6972
EssB is offline EssB  United Kingdom
Where is this output filtering ? I only see an SVO with 8 phase rectifier.
Simon
Old 24th September 2017, 06:44 PM   #6973
grandsons is offline grandsons  Switzerland
I just finished to clean a Shibasoku AG15B oscillator.
few kHz, 1Vrms un-terminated (well terminated by 100k Panasonic input load), third harmonic.
Nothing to measure....
Old 24th September 2017, 08:27 PM   #6974
RNMarsh's Avatar
Nice. and 2H, pls? same?
THx-RNMarsh
Old Yesterday, 08:02 PM   #6975
Here are the THD and THD+N measurement carried on my Shibasoku AG15B.
Analyser is Panasonic VP-7722A
Level 1Vrms on 100kOhm Panasonic input impedance
400HPF and 80kLPF engaged
cycles / THD+N / THD2 / 2Fo / 3Fo
10 /-112,5 /-135,7 / -140 / -140
100 / -111,7 / -134 / -140 / -140
1000 / -110,5 / -122,3 /-123 / -137,2
10k / -105,6 / -123,6 / -124,2 / -127,6
400HPF only
20k / -99,78 / -114,6 / -117 / -124,6
60k / -95,4 / -104,6 / -105 / -114,2
100k /-90,1 / -94,87 / -94,79 / -111,5
Anything I can do more?
This rescued Shibasoku from a bin looks good to me. I had trouble with noisy output level selector.
Any simple possible tweak?
PFB
Old Yesterday, 08:57 PM   #6976
I made an error in HPF vs frequency selection.
80kLPF only engaged
10 /-108,3 /-119,2 / -128,2 / -133,9
100 / -108,9 / -121,4 / -120,7 / -140
400HPF only
PFB
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
