Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 8th October 2012, 07:52 PM   #601
davada is offline davada  Canada
Originally Posted by dirkwright View Post
So, is this thread going to lead to a definitive "super oscillator" schematic, or is everyone just punting ideas around?
Yes we will come up with a super oscillator.
Eventually.
David.
Old 8th October 2012, 08:55 PM   #602
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Eventually.
Thanks.
Do you expect a group buy on some boards then? I'm just trying to get an idea on where this thread is leading. The goal, in other words.
Old 8th October 2012, 09:07 PM   #603
Thanks.
Well I suppose if one of us makes a break through boards may become available.
You have to clear what you're looking for.
Are you looking for inexpensive medium performance full range or expensive high performance full range? What about a price target?
David.
Old 9th October 2012, 12:53 AM   #604
dirkwright's Avatar
I like this one:
http://www.users.on.net/~glenk/thd/generator.pdf
which appears to be a variation of Bob Cordell's SVF oscillator.
but I'm willing to build an HP 239A clone (bridge T) also.
So, I guess the former comes under the expensive high performance full range and the latter is less expensive less performance, maybe? Why not both? Why not start with the former and make improvements to it (which I don't have any idea what those would look like)?
Old 9th October 2012, 01:17 AM   #605
I like this one:
Okay then put an SVO on a separate board from the AGC and multiplier.
This way you have an option for future modifications.
David.
Old 9th October 2012, 01:47 AM   #606
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Any definition/requirement for a "super oscillator"?
Old 9th October 2012, 02:22 AM   #607
jcx is online now jcx  United States
how about a "super multiplier" - one which gvies low harmonics of its diference product frequency output
then quite ordinary oscillators or DACs can feed it frequeny pairs
Old 9th October 2012, 02:34 AM   #608
1audio is offline 1audio  United States
Default Boonton 1121 AGC circuit
I have attached the Boonton 1121 AGC circuit. This circuit has fast settling and works without any time constant changes from 10 Hz to 140 KHz controlling a SVF oscillator.
Point c is the sine output, point b is the cosine output and point a is the dc voltage back to the AGC element (an analog multiplier in this case). The absolute flatness is in the .01 dB range across its full range. I don't know the settling time but its fast enough to use for swept measurements. An informal test from 500 Hz to 20 Hz showed no obvious change in level.
It may seem complex but all the other solutions are similarly complex and I would guess the cost of an extra wafer on a switch for range caps would not be much less expensive.
The HA2625 opamp is uncompensated and they used the compensation connection to limit the output swing to work with TTL. You would need a separate 5v supply for this circuit.
Demian Martin
Product Design Services
Old 9th October 2012, 02:37 AM   #609
Do you mean a good double balanced mixer, or a beat frequency oscillator? Beat Frequency Oscillator 700a Equipment General Radio
Demian Martin
Old 9th October 2012, 03:27 AM   #610
I ws thinking Gilbert Cell multipliers might be better suited to audio - but not certain of practical limits - obviously Spice perfectly matched Q models will give over optimistic results
and what are we practically aiming for -120, -140 dB for < 20? kHz harmonics + IMD, Spurs?? from 24/192 aduio DACs generating input sines in 50-100 kHz range
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
