Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 7th October 2012, 01:44 AM   #581
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by EssB View Post
The schematic in fig. 8.4 is a bit fuzzy but readable enough.
If you can read it then why don't you post it? Obviously, if I could read it then I wouldn't ask him for a clear copy!
Thanks for the link. very useful!
Old 7th October 2012, 01:53 AM   #582
EssB is offline EssB  United Kingdom
Because you already have it! see post 532 http://www.diyaudio.com/forums/equip...ml#post3182358
Old 7th October 2012, 02:01 AM   #583
dirkwright's Avatar
I'm sorry, I don't follow you. I have that manual. That's where I got the fuzzy figure. There is no figure 8.4 BTW.
Do you mean the attached schematic instead?
Old 7th October 2012, 02:08 AM   #584
Yes!
It says Fig. 8-4 in the bottom right corner
Old 7th October 2012, 05:48 AM   #585
1audio is online now 1audio  United States
The oscillator circuit it the same as the HP339a, schematic available here: http://bama.edebris.com/manuals/hp/339a look at pgs 103-106. Much better than the HP239 scans, just chopped into several pages. Much simpler than the KH4025 circuit but slower settling.
Demian Martin
Product Design Services
Old 7th October 2012, 08:41 AM   #586
coluke is offline coluke  Italy
Here is a better quality 239A (simplified) schematics.
Resistor values:
Ra = 10k (X 10 range), 1k (X 100, X 1k, X 10k range)
Rb = 100k (X 10 range), 10k (X 100, X 1k range), 1k (X 10k range)
R49 = 2k
C42 = 220u
Ciao,
L.
Old 7th October 2012, 01:26 PM   #587
dirkwright's Avatar
Resistor values:
R49 = 2k
C42 = 220u
Ciao,
L.
Thank you!
So, bear with me a minute about what they are dong here. Are they changing these resistors and capacitors for each range to change some kind of filter for each range? Are they changing the settling time based on which range is selected?
Old 7th October 2012, 01:28 PM   #588
dirkwright's Avatar
Thank you!
Old 7th October 2012, 02:02 PM   #589
dirkwright's Avatar
Resistor values:
R49 = 2k
C42 = 220u
Ciao,
L.
Now that I see this circuit more clearly, what is the input impedance for the node where CR1 connects to the output of the oscillator? Since the other end of CR1 is AC connected to ground via a capacitor Ca, I would think it would be a dead short for either some part of each cycle or for some corner frequency that I can't figure out right now. Should there be a buffer to drive this diode?
Old 7th October 2012, 04:38 PM   #590
Thank you!
Generator dynamics changes with oscillation frequency, so you have to change ALC loop gain and response time in order to optimize every range for both low THD and short settling time (and stability, too) - in general a single time constant loop can't work (and actually won't) from 10 Hz to 100 kHz with standard peak detectors. Heavy filtering will guarantee low THD but very long settling time; light filtering will shorten settling time at the expense of a much higher detector injected THD - there's a trade off. In the actual 239A THD @ 1 kHz is lower in the 10 X100 range than in the 1 X1k range, but the generator won't probably work @ 10 kHz in the X100 range...
As far as the schematics is concerned, my 239A clone includes a buffer just before the full wave detector, and it performs actually measurably better than the original one.
L.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
