Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 30th July 2013, 03:23 AM   #3021
1audio is offline 1audio  United States
Measured or sim? Measuring noise that low is not easy. I also think the model for the TL431 doesn't reflect how it operates in this configuration.
I'll set up one of the production units and measure it.
Demian Martin
Product Design Services
Old 30th July 2013, 03:35 AM   #3022
davada is offline davada  Canada
Simmed of course. I'm not that fast at putting circuits together. What is it in reality?
I added a bit to it. I can't get a spectrum from it 10 seconds after settling.
The four LM317 are because of a current limit in the model.
David.
Old 30th July 2013, 03:44 AM   #3023
Do you have a negative version of this?
David.
Old 30th July 2013, 04:07 AM   #3024
I have measured it. I had to build a transformer input "pre-preamp" to be able to measure something. It was in the 1 nV/rtHz range but I'll redo the measurement and document it.
Let me sketch a negative variation. I also did a shunt variant but have not built it. Do you need tracking? I think that would be important in some applications.
Demian Martin
Old 30th July 2013, 04:19 AM   #3025
May as well add the tracking. I plan to put the power supply in it own enclosure.
I want to keep that transformer as far away from the oscillator as possible.
Also see what the influence on noise of C2 is. It not costing much to make it a high value.
In sim the settling is a few hundred uV so who cares.
David.
Old 30th July 2013, 05:45 AM   #3026
Default Split Supply
Here is a first pass at it. Making the cap on the TL431 larger really slows down the startup. I did some tweaking but still room for more. The opamp can be pretty much any generic if the tracking doesn't need to be perfect.
I will "noodle" on an alternative solution that may work better. can you run the unbalanced loads from a different supply (Relays, ADC/DAC etc)? That will allow for almost zero ground current.
Demian Martin
Old 30th July 2013, 11:46 AM   #3027
jackinnj is offline jackinnj  United States
jackinnj's Avatar
In the "widget" thread you had mentioned that LTSpice doesn't have an TL431 model. Christophe Basso put one together for his book: "Switch-Mode Power Supplies":
.SUBCKT TL431 1 2 3
C1 3 20 43p
Q1 3 20 10 QN3904
R1 10 7 240
R2 7 2 6600
Q2 3 7 2 QN3904 50
D1 1 3 D4mod
D2 2 3 D2mod
V1 5 2 DC=2.49
R4 3 0 1e12
D3 2 20 D3mod
C2 2 7 1n
G2 2 20 5 1 -250e-6
.model QN3904 NPN AF=1.0 BF=300 BR=7.5 CJC=3.5pf
+IKF=0.025 IS=1.4e-14 ISE=3e-13 KF=9e-16 NE=1.5
+RC=2.4 TF=4E-10 TR=21E-9 VAF=100 XTB=1.5
.model D3mod D N=0.01
.model D2mod D BV=36 CJO=4E-12 IS=7E-9 M=0.45 N=1.3
+RS=40 TT=6E-9 VJ=0.6V
.model D4mod D BV=100V CJO=4E-12 IS=7E-9 M=0.45
+N=2 RS=0.8 TT=6E-9 VJ=0.6V
Old 30th July 2013, 02:39 PM   #3028
The unbalance load is not quite so unbalanced. There is a strong negative current, almost equal on the one of the -7V legs which should balance thing up. The shunts can be adjusted
to make up the difference. I don't care if a bit of current gets pissed away doing this.
But to answer the question I can do what ever I want.
I can separate the power rails but I can't separate the grounds because of how the currents resolve. Everything is cascaded digital to analog. The best thing to do is keep the current localized and short looped. I'm using compression terminals on the board. I can add extra contacts for the proto board. This way I can ties the legs together or power them separately. All power is routed to the same entry on the board. I don't want to get too crazy with thing unless the need arises. The only part of the digital that can be separate is the relays and drivers and micro controller to a point. The Micro is on it's own board anyway but it also has to connect to the tuning dacs which have only one ground pin. But like I said the tuning is only active when there is a change.
This is tricky business.
It doesn't have to be tracking if that's easier to do. Ground current will only balance on average anyway.
David.
Old 30th July 2013, 03:22 PM   #3029
I like the addition of the 10k to reference and smaller C2. It's here the noise gets amplified.
David.
Old 30th July 2013, 04:26 PM   #3030
It also reduces a parallel path for noise. Remove the cap across R1 and change the cap on the TL431 to 1 uF. In the simulation the turn on transient is much better behaved.
I substituted some larger transistors and increased the load current here. I think it needs more analysis before going live. I can add current limiting with some simple parts I think.
If the unbalanced currents are small I think an active center tap and a floating supply will be lower noise from external stuff and easier to make work well.
Demian Martin
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
