Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 8th May 2013, 07:11 AM   #2611
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by davada View Post
How's this for almost 20kHz.
The lamp multiplier didn't work out. Too microphonic when the lamps are hot.
I moved on to another multiplier idea of mine which is rather unusual.
Very good !
Old 8th May 2013, 07:12 AM   #2612
RNMarsh's Avatar
Originally Posted by Samuel Groner View Post
Notch depth is not of cruical importance for a THD measurement (it is for THD+N, though).
Samuel
I agree.
Old 8th May 2013, 07:31 AM   #2613
RNMarsh's Avatar
Default Audio precision 2722 specs
Here are the "typical" performance THD+N numbers et al for the Audio Precision 2722.
This is to compare against our oscillator results.
Thx-RNMarsh
Old 9th May 2013, 02:12 AM   #2614
RNMarsh's Avatar
Default Analyzer compared
Here is the THD+N from the same signal generator and looking at two different THD analyzers' residual output/monitor ports.
First is from Panasonic VP-7722A, second is from ShibaSoku AD725D analyzer;
Thx-RNMarsh
Old 9th May 2013, 03:08 AM   #2615
RNMarsh's Avatar
The modified 339A also seems to attenuate the upper harmonics. And/Or it doesnt resolve as well as 725 does. Similar to 7722.
Thx-RNMarsh
Old 9th May 2013, 03:14 AM   #2616
1audio is offline 1audio  United States
What would help a lot would be to add a marker at a known level, say -120 dBC. You will need some matching/mixing network that matches impedances and levels. The attenuator on the KH or the AG16 should be good enough once the basics are established. Victor suggested this idea. I tried it and it works well. It won't show on the analysis output of the 725D. I even tried to match the frequency of a harmonic. You could easily see the beats.
Demian Martin
Product Design Services
Old 9th May 2013, 05:31 AM   #2617
RNMarsh's Avatar
Demian.... it isnt relavent to these pictures. You only need to see the 3H is lower in some analyzers -compared to the 2H. It could be 10% THD... or .001% THD it doesnt matter.
[I also did as you suggested already and pointed out some interactions with that signal a few lines back.]
Here, I dont care what the absolute levels are. I am showing differences in the recovered Harmonic levels for the same input voltage/source/freq.
If the 2H and 3H do not have the same relationship in level to each other then what are some of the possible explanations for it ?
With the 725, the 2H and 3H are at similar levels to each other. With the other analyzers, the 2H is much higher than the 3H.
Thx-RNMarsh
Old 9th May 2013, 05:55 AM   #2618
RNMarsh's Avatar
I just read my voice mail--- from ShibaSoku Rep.... he called factory -- they cant/won't sell me a service manual.
-RNM
Old 9th May 2013, 06:03 AM   #2619
Samuel Groner is offline Samuel Groner  Switzerland
Originally Posted by RNMarsh View Post
If the 2H and 3H do not have the same relationship in level to each other then what are some of the possible explanations for it?
Well, I'm quite desperate as I've tried to explain this issue probably half a dozen times now... Apparently I can not phrase this good enough. Surely this text (page 44ff) does better:
http://cds.linear.com/docs/en/applic...note/an43f.pdf
In particular make sure you follow the section on "Distortion Measurement Accuracy".
Samuel
Old 9th May 2013, 06:38 AM   #2620
davada is offline davada  Canada
Basically when it come to distortion measurements we're screwed.
Good article.
David.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
