Low-distortion Audio-range Oscillator Low-distortion Audio-range Oscillator - Page 256 - diyAudio
Equipment & Tools From test equipment to hand tools
Old 1st May 2013, 06:36 PM   #2551
davada is offline davada  Canada
If there is going to be an a DSP involved why not just use one convertor. Store the period of a single cycle and sum it with the next cycle. This can be done recursively for any number of cycles. The output can be any convenient audio format.
Or just do what the 725 does and output that to a convenient audio format rather than reconstructing the signal and analog processing.
LT has a app note for this.
Look at figure 4. This can be modified to do the job.
http://cds.linear.com/docs/en/lt-jou...d_1100_Mag.pdf
David.
Old 1st May 2013, 07:54 PM   #2552
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
That could work as well. This sort of thing is the natural next step for a hyper-low distortion test system.
The Panasonic VP-7722A has just arrived to see what it's potential is and how well it works.and what is the design used. has great specs, uses DSP etc.
[>-140dB 2H rejection spec. THD <.0002% spec. Designed for to be fully automated for production testing of 10 parameters or more]
Thanks,
Richard
Old 1st May 2013, 08:36 PM   #2553
RNMarsh's Avatar
The VP-7722A is similar to the ShibaSoku AD725D in THD resolution (using its own generator output to it's 7722 analyzer input displays a THD level of .00005%. So thats a good beginning. Have to look at the monitor port residuals with FFT. Measures individual harmonics like the 725 does. It also does IM and a host of measurements.... might be the one for you guys to find before prices go thru the roof on it. I paid $1k for it on eBay. I had found the 725D on eBay a microsec after it was put there asking only $450 and snatched it up. Later, I saw a refurbished 725d on another site going for $12K ! Good deals do exist from time to time.]
-RNM
Old 2nd May 2013, 04:51 AM   #2554
1audio is offline 1audio  United States
I'm sure its a really nice bench tester. Its new enough that it will have the sharp low pass filter necessary to measure distortion on digital sources. Since its defined by numbers and the Japanese have an obsession with performance execution it will be a really good instrument.
Demian Martin
Product Design Services
Old 2nd May 2013, 05:38 AM   #2555
This is what the melt noise is doing on the QA400. Unfortunately the trigger/clock must be precisely synchronized with the signal or both the signal and the noise "melt". If the QA400 had a continuous mode it would be possible to lock an external oscillator.
Demian Martin
Old 2nd May 2013, 02:03 PM   #2556
I noticed that with the melt. It took the signal down too.
Needs a little work.
David.
Old 2nd May 2013, 02:06 PM   #2557
Hi Demian,
Is windows audio capable of any sample rate or the just the common audio sample rates?
David.
Old 2nd May 2013, 02:21 PM   #2558
If you use it in loopback the signal should not change. Any synchronous component will be reinforced. Any noise/randomness will get reduced. It does seem to work for me.
Demian Martin
Old 2nd May 2013, 02:24 PM   #2559
Hi Demian,
Depends- The windows sound engine supports a standard list of sample rates and resamples everything to the default rate of your system. Its not a particularly good resampler and should not be used in any measurement process. If you use something like ASIO you can go around the sound engine somewhat, if your soundcard driver and application supports ASIO.
Demian Martin
Old 2nd May 2013, 03:00 PM   #2560
Will ASIO support any sample rate?
David.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
