Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 31st January 2013, 12:12 AM   #1651
davada is offline davada  Canada
Originally Posted by richiem View Post
My experience with the active twin-t is that 40dB of fundamental attenuation is enough, but I like to use 60dB to be sure. I'm at the point where I don't know if it's the active filter or the oscillators I have that are my limiting factors for spur amplitudes. I really want to know, but I need a 1kHz oscillator that I know has all spurs at least -150dBV in order to verify. If anyone can assure me that Victor's oscillator will do that, then I'm all over it.
Hi Dick,
I don't know about -150dB but they are stunningly quiet.
Still waiting on some decal material to label the case for the TT. Once I have that the TT should be assembled and I'll send you some measurements.
David.
Old 31st January 2013, 12:32 AM   #1652
1audio is online now 1audio  United States
John Curl suggested using a shunt cap to add an extra -6 dB/octave reduction in the harmonics of the source. I can't say that would be enough to address these issues or would even work at this level.
Demian Martin
Product Design Services
Old 31st January 2013, 12:34 AM   #1653
As a passive LP?
David.
Old 31st January 2013, 12:47 AM   #1654
Sorry for not being clearer, yes.
Demian Martin
Old 31st January 2013, 01:44 AM   #1655
Hi Demian,
You can try this. It does work but with a variable tuned oscillator it means one more circuit stage to tune.
David.
Old 31st January 2013, 05:57 AM   #1656
Samuel Groner is offline Samuel Groner  Switzerland
With the two trim technique I seem to be able to walk to a >70 dB null even with just 2 single and one 2-parallel caps. I think the pots can be made a small enough portion of the resistor to not be an issue.
It all depends on what trim range, operating level and distortion contribution we're looking for. I'm just saying that the wiper contact resistance can be really, really bad (that applies even for the bulk metal trimmers--the $$$ I've spent for those were a complete waste), depends on the position, varies a lot from specimen to specimen and may go bad over time. So for stuff approaching -140 dB I'm inclined to prefer selected parallel resistors to trim the center frequency to its nominal value. If trimmers are included, it might be helpful to arrange them such that one end is at (virtual) ground if possible--so one could measure their distortion contribution in isolation.
Maybe you can shed some light on how Weiss would verify the distortion numbers quoted for this amp module: http://www.weiss-highend.ch/op-amp/d...bipolar_r1.pdf . They seem too good to be true. For $130 ea. they could be a great value. That's close to the internal cost for the modules I designed for Nuforce.
The quoted figure is the input referred harmonic distortion voltage. This is quite easily measured by running the amp at high noise gain, and subtracting the noise gain from the measurement. Same trick as I've used for the opamp measurement series (although I did not subtract the noise gain there), and what TI uses for their IC opamps.
Samuel
Old 31st January 2013, 07:21 AM   #1657
Originally Posted by Samuel Groner View Post
I'm just saying that the wiper contact resistance can be really, really bad (that applies even for the bulk metal trimmers--the $$$ I've spent for those were a complete waste), depends on the position, varies a lot from specimen to specimen and may go bad over time. Samuel
Which version of the trimmer? My experience has been much better but none of mine are less than 10 years old.
Samuel
I see, that is measured in the way TI, Burr Brown, AD and National do it. Probably the only way to measure such low levels of distortion.
Demian Martin
Old 31st January 2013, 07:32 AM   #1658
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by RNMarsh View Post
Awhile back i suggested taking oscillator distortion and inverting it and adding it back to cancel distortion. No takers. One way is as a unbal to bal converter using a bridge configuration to cancel thd... see below;
And the other is an iteritive circuit (using unbal/unbal). This can be used as the basis to make an oscillator of zero distortion. trim the values to null output thd. see below;
Pre-amplifier and power amp circuits can be made this way as well - using the error take-off point to cancel thd. It overcomes the basic limitation of neg fb which is - increasingly limited open loop gain with increasing freq. [Very low thd at very high freq can be accomplished this way]
[invented by A.M.Sandman] Thx RNMarsh
Last edited by RNMarsh; 31st January 2013 at 07:43 AM. Reason: low thd without gnfb -
Old 31st January 2013, 07:44 AM   #1659
This is much smaller.
I use those for some simple circuits like R-R attenuators, RC filters or diode clamps. I agree with Demian that these are pretty tight for a notch filter, but it might work out with some care.
1248W--larger versions probably have lower wiper contact resistance.
Samuel
Old 31st January 2013, 07:49 AM   #1660
It might theoretically reduce amplifier distortion contribution towards arbitrary low levels, but it does nothing whatsoever about passives, layout effects, contribution from multiplier and level detector ripple... These are the real challenges.
Samuel
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
