Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 7th January 2013, 08:32 AM   #1481
1audio is offline 1audio  United States
Originally Posted by davada View Post
Hi Demian,
Dead link there.
The link is live again. It describes how the Agilent 3458 DVM gets exceptionally accurate AC voltage measurement (3 ppm) with undersampling. The max sample rate is 250 /second I think and it measures TRMS to 150 KHz. I think you could apply the same principle with a PIC (not get 3 ppm) but get good enough accuracy pretty easily with its internal adc. Add a mux and a good vref to self cal periodically to improve long term stability.
Another option if you are looking at pure sine waves is to borrow from an incremental voltmeter. You could amplifiy just the voltage range +/- 5% around the peak voltage to match the range of the ADC. If no samples are in range need more gain in the oscillator. If samples hit the positive limit reduce. The max voltage of any sample would be the peak value + noise + ADC errors. Collect and look at samples and you can determine the frequency as well as the max amplitude.
What frequency resolution and accuracy are you seeking? For that matter voltage accuracy and stability etc? SG's question is relevant since these all affect the device design and component performance.
Demian Martin
Product Design Services
Old 7th January 2013, 09:19 AM   #1482
Samuel Groner is offline Samuel Groner  Switzerland
I don't need a fast detector for what I'm doing. These methods wouldn't work for a conventional multiplier like a Jfet type. Other detection methods are being discussed for an already stabilized loop that just needs to be brought to a reference level.
A slow loop still needs to meet stability constraints... And if the loop is slow you can much more easily apply lots of low-pass filtering, so why looking for anything more than a simple two-way rectifier? I think the problem you're facing has been solved already by many others, so don't try to re-invent the wheel!
There is an 1968 IEEE paper which shows exactly what you want to do (as far as I understand)--"fast" stabilization by a thermistor/lamp, and slow stabilization by a linear leveling loop:
Skehan, B.J.
Design of an amplitude-stable sine-wave oscillator
Solid-State Circuits, IEEE Journal of
Sept. 1968, Volume 3, Issue 3
Samuel
Old 7th January 2013, 09:22 AM   #1483
That's pretty much what's been done in the AP System One.
Samuel
Old 7th January 2013, 05:01 PM   #1484
I thought it was a good idea.
Demian Martin
Old 7th January 2013, 05:51 PM   #1485
It is, and a major contributor why the generator of this unit is as good as it is!
Samuel
Old 7th January 2013, 06:20 PM   #1486
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
A little off course But -- why wouldnt a jFET be enclosed within an opamp feedback loop to linearize it for this app as being used in original 339A?
Old 7th January 2013, 08:20 PM   #1487
davada is offline davada  Canada
Hi Demian,
Thanks for the link.
I got a 401 a couple time. Dimitri sent me the pdf. I tried the link again and it worked the third time. My internet been acting weird lately.
The PIC has 13 analog IO two of which are reference inputs. Two comparators. Two event captures on either rising or falling edges. SPI, USB, 4 timers and more IO ports than you know what to do with. This is alll hardware modules separate from the processor. All in a 28 pin dip package. Quite handy little device. But still not suitable for real time work over 1KHz on the SPI side. I do have it setup for frequency counting 1Hz resolution 40MHz.
What your suggesting with the incremental voltmeter is technique that artificially increases
an ADC's resolution. This can also be helped along by narrowing the ADC input range by setting the reference higher and offsetting the (-) input pin. The PIC has pins for this option. If we can cram the 10bits into a 78.125mV span we have an equivalent resolution to 16bit over a 5V span. This can be set up with switches and a voltage diver network.
Sample once 10bit over 5V span then close in to 10 bit over a 78.125mV and a bit of math can make up a 16 bit word. Send that to a 16 bit DAC. If the PIC had two ADC this could be done simultaneously. I suppose the comparators could be used to find the coarse and then the ADC to do the fine.
It's a lot of fuss though and can make a guy's head hurt figuring it all out.
David.
Old 7th January 2013, 10:10 PM   #1488
johnfalc is offline johnfalc  United States
Default LDR sub for the 339A's E1 or E2 Vactrol
I've been following this thread with some interest, especially as it dwelt on the HP 339A for a while. Coincidentally, my 339A's E2 has failed open circuit on the LED side. The design note and data sheet from PE/Vactec was useful but I'm still unsure if the part used by HP maps to one of those listed therein. Stabbing in the dark I've ordered one each of the VTL5C1 and VTL5C2 but wonder if any of you have determined a contemporary replacement. My 339A is stock.
Old 8th January 2013, 12:23 AM   #1489
Hi John,
Not sure if those will work.
One thing you can try is to break the epoxy out on the LED side and find an LED to replace the one that's open. No doubt you can find some black epoxy at your local hardware store.
David.
Old 8th January 2013, 03:03 AM   #1490
David, Thanks for the suggestion, for the sake of learning, I'll try the commercial devices and if they don't work I'll go the route you suggest ... if I do I'll have to decide on an LED color, I wonder if the VR part of the device is CdS. John
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright ©1999-2017 diyAudio
