Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 6th January 2013, 03:51 PM   #1471
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by davada View Post
From it's description I think the Shibasoku is a heterodyne process. It's a very sophisticated selective voltmeter.
But since no one has a service manual for it who knows.
AFAIR you are close, I once actually had a manual . I posted those parts and literally as the letter dropped into the bin I overheard the postmaster warning the next customer not to put anything non-flat in the generic mail box, hopefully it won't jam the automatic sorter. Keep an eye out, there are plenty more.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 6th January 2013, 04:00 PM   #1472
Here's my plot of the PV/FET circuit, a 1500/100 Ohm bridge, nulled against another 1500 Ohm resistor and the FET (J310) tuned to 100 Ohms. The seconds can be nulled to almost the noise (I used .033u across the PV don't know how low you can go). This is at ~.9V p-p on the FET, if the distortion is low order it should drop dramatically (60dB/dec) at lower levels.
This is about as good as I could null the fundamental stepping 1mV or so at a time on the PV drive (100 Ohm in series with the LED).
Old 6th January 2013, 04:08 PM   #1473
davada is offline davada  Canada
LOL.
I got ____ for that once too.
It's about postage not the machine jamming.
I mailed ordered some T03 can trans years ago. The guy stuck them in one of those padded flat packages. When I got them the pins were bent flat against the case. Maybe they go through a roller at the sorting facility.
David.
Old 6th January 2013, 04:49 PM   #1474
Originally Posted by jan.didden View Post
Lock-in amplifier principle? I've been looking at some PAR units, but not sure if it is worth the hassle.
jan
Hi Jan,
You have giving a very interesting idea for a peak detector similar to lock in amplifier.
Thanks,
David.
Old 6th January 2013, 04:55 PM   #1475
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Why does the cap drop H2? Thx-RNMarsh
Old 6th January 2013, 05:04 PM   #1476
Samuel Groner is offline Samuel Groner  Switzerland
I'm completely lost now--why are we talking about subsampling techniques, FFTs and lock-in amplifiers as level detector for the amplitude stabilization loop? The response of the level detector needs to be fast (ideally within a small fraction of a period), or loop compensation will become a tremendous nightmare. Also we neither need ppm precision nor are we looking for µV signals burried in noise..?
Samuel
Old 6th January 2013, 05:29 PM   #1477
Non-linear Cgd and Cgs, the PV looks like a current source so the displacement current directly adds to the control signal.
Old 6th January 2013, 07:01 PM   #1478
Samuel
Hi Samuel,
There is more than one subject being discussed here.
I don't need a fast detector for what I'm doing. These methods wouldn't work for a conventional multiplier like a Jfet type.
Other detection methods are being discussed for an already stabilized loop that just needs to be brought to a reference level.
Additionally these methods can be used for other purposes that don't require fast loops like auto null etc.
David.
Old 6th January 2013, 08:15 PM   #1479
This one I'm optimistic about. I think it might be fast enough for conventional loops.
This is a functional simulation.
The signal source is squared by a multiplier. The signal source is feed to the input of a VCA and it's output is squared by a multiplier. The squared source and VCA are input to a differencing amplifier and the output of the difference amplifier feeds an integrator. The DC from the output of the integrator provides an error signal Vc for the VCA. When the squared source and squared output of the VCA are equal the output of the difference amplifier is null, 0Vdc average and the ripple component is in the low uV's. If the output of the VCA is less than the source the DC component at the output of the difference amp is negative and the integrator ramps up. if the output of the VCA is greater than the source the DC component at the output of the difference amp is positive and the integrator ramps down. The system locks the VCA output level to the amplitude of the source and the output of the integrator is a DC value equal to the peak of the source.
The speed of the system response is dependent on the response of the multipliers and the tau of the integrator. The output ripple is a function of the null and not a function of frequency. Therefore the integrator TC can be short. The LP effect of the integrator does help to minimized the ripple though.
The system is not sensitive to component tolerance and any error can be trimmed out.
The last two plots show output ripple from the integrator. The second one for a longer integrator tau.
David.
Old 6th January 2013, 08:27 PM   #1480
This is a 10Hz 1V modulation on a 5V 1KHz signal to show the tracking of the output signal from the integrator.
I hope it works in practice.
David.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright ©1999-2017 diyAudio
