Low-distortion Audio-range Oscillator Low-distortion Audio-range Oscillator - Page 147 - diyAudio
Equipment & Tools From test equipment to hand tools
Old 5th January 2013, 08:13 PM   #1461
1audio is offline 1audio  United States
Here is a really good approach to measuring the voltage using sampling techniques. http://www.home.agilent.com/upload/c...?&cc=US&lc=eng I don't think you need to go to the 3 ppm capability of the HP3458 to get value from this and if you had both level and frequency you could steer both to the desired values with a PIC or Arduino. (Linuxworks, where are you?)
Demian Martin
Product Design Services
Old 5th January 2013, 08:13 PM   #1462
davada is offline davada  Canada
Originally Posted by RNMarsh View Post
It doesnt look too unwieldly and a pcb is already made to try it with. Now... what is the goal, again? The cause of thd that this is going to affect a reduction? Just checking... sort of a resync operation. -RNM
Hi Rick,
The FFT calculates and holds the peak. The peak is compared to a reference level and then
output to an integrator. The integrator's job is to find the DC value output to the multiplier which satisfies the loop requirements for the reference output level. The PIC would output a value to a DAC connected to the lamp drivers.
We only need a single frequency output from the FFT. Only the bins closet in to the FR are needed and anything that spills into adjacent bins ,AKA buckets, can be added back the FR peak. Since there is only one frequency of interest we can allow the FFT to wrap around the nyquist. It will show up as a lower alias frequency peak. Therefore sample rate limit of the PIC's ADC is not really a problem.
The question is how low a sample rate can we use?
The number of samples sets the number of bins. The fewer bins means more bandwidth is crammed into one bin including noise.
The second question is how few number of samples can we get away with and still have a reasonable accuracy. There is also the question of bit depth. Is 10 bits enough.
The smaller the FFT is the faster it computates.
The project in the link is a toy not an instrument.
I,m no expert on FFT so if anyone is more knowledgeable please comment.
Microchip has a white paper on using FFT as a peak detector.
I already have a development board for the PIC18F2455 which is the same as the PIC18F4550 just fewer IO ports.
David.
Old 5th January 2013, 09:02 PM   #1463
Hi Demian,
Dead link there.
David.
Old 5th January 2013, 09:05 PM   #1464
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
David, check your e-mail
Old 6th January 2013, 12:16 AM   #1465
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by davada View Post
Hi Rick,
Something similar to this I figure ShibaSoku harmonic distortion analyzer is doing... displays the individual harmonics peaks from an FFT was my guess. -RNM
Old 6th January 2013, 12:38 AM   #1466
From it's description I think the Shibasoku is a heterodyne process. It's a very sophisticated selective voltmeter.
But since no one has a service manual for it who knows.
David.
Old 6th January 2013, 05:11 AM   #1467
RNMarsh's Avatar
It appears to be treated as a top secret national treasure.
Old 6th January 2013, 06:57 AM   #1468
jackinnj is offline jackinnj  United States
jackinnj's Avatar
For $149 you can get a Texas Instruments evaluation module with FFT software. These are wonderfully designed and built kits.
Old 6th January 2013, 07:05 AM   #1469
jackinnj's Avatar
You could do this, then, with an HP 3586 Selective Level Receiver programmable via the HP-IB.
Old 6th January 2013, 07:34 AM   #1470
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Lock-in amplifier principle? I've been looking at some PAR units, but not sure if it is worth the hassle.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
