Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 30th December 2012, 11:16 PM   #1391
davada is offline davada  Canada
Originally Posted by scott wurcer View Post
Surprised you can't null the seconds, do you have exactly what you did?
Hi Scott,
I used the exact circuit you posted.
Instead of using 100k resistors I used a 200k multi turn post wire the same.
A 1 meg resistor parallel the PV and a 1K LED bias resistor.
The whole works connected to the jfet as you indicated. The LED was connected directly to the output of the AGC fet driver op amp and the AGC output was disconnected from the jfet.
Nothing else was changed or different from the original connections.
The only thing missing from this configuration is the coupling capacitor in series with the jfet feedback resistor which adds a bit of filtering.
C30, R51, R50 disconnected and floating. PV LED connected to pin 14 through 1K res.
This may have been the difference.
David.
Old 30th December 2012, 11:18 PM   #1392
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
David, are you playing with optocoupler with photovoltaic output and 339a JFET A1Q2 or
with photo FET optocoupler?
http://pewa.panasonic.com/assets/pcs...er-catalog.pdf
http://www.fairchildsemi.com/ds/H1/H11F1M.pdf
Oh, I see... Correct?
Old 30th December 2012, 11:26 PM   #1393
Oh, I see...
Hi Dimitri.
The Panasonic APV1122A.
Those other things are terrible.
David.
Old 30th December 2012, 11:35 PM   #1394
dimitri's Avatar
photo FETs? slow?
Old 30th December 2012, 11:43 PM   #1395
photo FETs? slow?
A lot of distortion too for a part that says distortion free in the data sheet.
I was very disappointed.
David.
Old 31st December 2012, 12:46 AM   #1396
Default Update on 339a mods
I've done a few more mods to the 339a oscillator and to the balanced modulator board.
I replaced the level pot in the oscillator with a Bourns 10k cermet. This squashed a large 3rd H I just couldn't seem to get rid of. This was a repair.
I replaced the VCR2N with PN4392 Jfet which drove both 2nd and 3rd H down further.
I bypassed the capacitor C30 in series with R51 and added a 100uF electrolytic cap in series with R52. I replace trim pot R30 with a cermet single turn 2K pot.
With some tweaking of the amplitude level trim and distortion trim pots got the following results from the oscillator.
The balance modulator board has R5, R6, R32 and R33 changed to 10k. R7, R8, R34 and R35 changed to 1K. I added a balance 10k trim to A3U4 wired same as the balance trim for A3U2. CR1 and CR7 are removed and R10 and R39 are bypassed with a jumper.
A3U1 was replaced with a 1468 in a earlier mod and R1 is set at 200 ohms.
All trim pots are changed to multi turn cermet pots.
This reduced the noise and distortion when setting the balance trims.
The balance trims are set by probing the test points ATP1 and ATP2 with FFT at 1KHz and tweaking the trims for minimal level of signal and harmonics on the the test points.
Here are the results.
I will confirm this measurement once my Twin T is assembled.
Still waiting on some parts.
David.
Old 31st December 2012, 04:19 AM   #1397
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by davada View Post
Hi Scott,
Ok, I'll check it out myself, I seem to have a whole week off and nothing but dreary weather ahead. What I want is to check just three or so spot frequencies and I'm happy with fixed oscillators and twin tee filters.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 31st December 2012, 02:27 PM   #1398
vicnic is offline vicnic  Latvia
Hi Scott,
I don't like this very big and nonlinear (PV) resistance at FET's gate. In my opinion, PV must be shunted with capacitor (but this make time constant) and so big pot for trimming not needed - you can change this pot to some kohms without problems.
Old 31st December 2012, 03:07 PM   #1399
Hi Victor,
I changed the resistors to 1K with no change of behavior. The 2nd H was up about 8dB
from norm. How much nonlinear are we taking here, more than a jfet?
Other than that I found them to work quite well.
David.
Old 31st December 2012, 03:48 PM   #1400
Hi Victor,
Hi David,
I don't see other reasons for distortions increasing, as circuit at FET's gate. PV also has very big and nonlinear output resistance. I don't know, how big effect it makes - needs calculating or measuring. PV output resistance in series with FET's gate capacitance (also nonlinear).
Maybe you can shunt PV with capacitor (about 1000pF) for experiment...
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
