Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 30th December 2012, 06:17 AM   #1371
1audio is offline 1audio  United States
Default AC level detector
Here is one could do the job:
http://www.thatcorp.com/datashts/THA..._Datasheet.pdf 80 KHz max. Most of the current devices are focusing on 800 MHz to 2 GHz.
Attached is the simplest peak detector I could think up that would work. The LM339 is an open collector comparator. The input circuit is very like an opamp and what happens here is the the output follows the input until it goes positive. Since its open collector the output is then limited by the charge on the cap and the pull up resistor. Because its a moderately fast comparator the internal circuitry doesn't latch up or slow down when there is significant differential on the inputs. I have used this in several applications in the past and it worked well. And you have three more sections of the LM339 to do useful things with.
Demian Martin
Product Design Services
Old 30th December 2012, 07:10 AM   #1372
davada is offline davada  Canada
"Here is one could do the job:
http://www.thatcorp.com/datashts/THA..._Datasheet.pdf 80 KHz max."
If I used enough of this sort of thing in cascade I should be able to push the ripple frequency right out of band. But it would cost a small fortune.
This one is a possibility.
Thanks,
David.
Old 30th December 2012, 10:46 AM   #1373
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Thanks,
That's an IC version of the old DBX rms detector. When I visited DBX in 1977 they showed me a "blessed" one that came out with 120dB range that was enshrined with a huge analog readout meter as their "lab standard".
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 30th December 2012, 04:18 PM   #1374
Hi Scott,
I was thinking that the ripple out of a squaring rms detector, like the AD536 or the ones you sent me, is double the frequency of the input. They accept dc so if I put a number of them in series it should multiply the ripple moving it up the bandwidth. Less filtering would be needed or better smoothing for the same amount of filtering. We don't need accuracy just repeatability and it should cover the bandwidth of interest. But these IC's are expensive. Is there another device that will do the same at a lesser cost.
This is building on an idea Dick Moore gave me some time ago.
Edit;
Come to think of it these devices double the frequency of AC. The output of the rms detector is dc with a ripple component that is not ac so it won't work.
David.
Old 30th December 2012, 04:37 PM   #1375
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
First think of the very Best Way.... for best results. Then pay the cost to do it Best Way. Dont throw away the best way because it cost more. Too much consideration to an IC cost, other parts cost. Thx-RNMarsh
Old 30th December 2012, 04:46 PM   #1376
Good advise Rick.
Okay Infinite sample and hold it is then. ADC to MDAC. No ripple.
So what if I have to give it a long time constant. The output will be pure.
Thanks,
David.
Old 30th December 2012, 04:53 PM   #1377
RNMarsh's Avatar
Ok then lets do it that way. The best way for best performance.
[BTW--Did you look at the AD8436 (90dB dynamic range). An input amp with approp scaling will extend it]
Thx-RNMarsh
Old 30th December 2012, 05:17 PM   #1378
Thx-RNMarsh
Yes I have looked at that but the package turned me off. It's the same as all other rms detectors. We still have a ripple component at the 2nd H to deal with.
ISH has no ripple at all or droop. There is a some glitch from MDAC switches but the integrator
in the proportional controller takes this out.
David.
Old 30th December 2012, 05:46 PM   #1379
RNMarsh's Avatar
OK. Then that is the way to proceed. Thx-RNMarsh
Old 30th December 2012, 05:58 PM   #1380
Samuel Groner is offline Samuel Groner  Switzerland
ISH has no ripple at all or droop. There is a some glitch from MDAC switches but the integrator in the proportional controller takes this out.
If the controller has proportional action (and it needs this to be fast settling) there is by definition no (significant) low pass filtering. So glitches surely contribute some distortion.
Samuel
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
