Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 25th December 2012, 10:27 PM   #1311
davada is offline davada  Canada
Originally Posted by jackinnj View Post
Some folks who built Millet's RMS converter experienced noise issues with USB.
If I had to design a piece of audio instrumentation communicating via USB I'd isolate it (Analog Devices has a development kit for around $50, which you can do for a fraction if you SMT, same with other folks), and use a linear supply on the business end.
Hi jakinnj,
Dick Moore bought one of those AD demo boards but couldn't use it because it only does full speed. The EMU0204 and QA400 use high speed.
If we could interface to ethernet and back we have the galvanic isolation or something else
balanced.
David.
Old 25th December 2012, 11:40 PM   #1312
1audio is offline 1audio  United States
Default QA400 interface
Here is a sketch of what I'm working out. Its missing gain calibrations, common mode trims, output protection etc. It will give the general idea however. I'm using the THAT parts because they have a pretty high level of integration and take care of a bunch of precision resistors. I don't know yet if they will limit either the noise or distortion. Alternatives would be very interesting to look at. These are also available in DIP packages making them easier to deal with and, if socketed, easier to recover after mistakes.
Input protection uses small fuses (.062A fast blow). I may be able to simplify the output amp if the QA400 can drive a lower Z load without degradation. The opamp is a placeholder. Not figured out yet is power supply and possibly a local reference oscillator (1 KHz, light bulb stabilized, lockable from the QA400).
Demian Martin
Product Design Services
Old 26th December 2012, 01:16 AM   #1313
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by 1audio View Post
Here is a sketch of what I'm working out. I don't know yet if they will limit either the noise or distortion. Alternatives would be very interesting to look at.
That is a pretty important issue -- the front end interface adding to the measured DUT distortion. -RNM
Old 26th December 2012, 01:20 AM   #1314
RNMarsh's Avatar
Originally Posted by mkc View Post
I'm sure you know Glen's project: An Audio T.H.D. Analyser
Best regards,
Mogens
His whole analyzer looks well thought out. I'm thinking of getting just the oscillator part to check out. -RNMarsh
Old 26th December 2012, 02:24 AM   #1315
The THAT parts were suggested to me by Bill Whitlock of Jensen transformers. He said they would be a good option for the AP input stage. Until I get my hands on something I can't tell on way or the other. I suspect that for most audio work they will be more than good enough. The cluster of parts to do it with other circuitry gets huge. The similar input board for the Boonton is 4" X 12" with not much vacant real estate. Paralleling opamps to lower noise can work. On a Yamaha tuner I have they paralleled (without balancing resistors!!) two opamps on the same die and got a real 3 dB improvement. I don't know if that would work here. The biggest constraint is the input attenuator impedance. 10K for 100V RMS is 1W, which has impact both in the source loading and in the size of the components. Going smaller would not be an option I think. The industry standard is actually 100K.
Demian Martin
Old 26th December 2012, 02:45 AM   #1316
Hi Demian,
All the resistor in the 339a input attenuator are 2 - 3 watts. The 339a input has to be able to blow the fuse with 300V without the resistor catching fire. I would think as an added bonus the resistors in that size would be more thermally stable because of the extra mass.
David.
Old 26th December 2012, 08:19 AM   #1317
Samuel Groner is offline Samuel Groner  Switzerland
The LT supper oscillator is a tuned composite amplifier to make it work at 10 kHz. Generally the compensation of two amplifiers in series raps the phase around through 180 deg and beyond before reaching unity. So they are unstable.
To satisfy stability requirements, we need >0° phase margin at the unity loop gain frequency only. At frequencies where loop gain is large, phase margin can be what it wants, even negative.
The LT "super oscillator" doesn't oscillate because the opamps are unstable. It oscillates for the same reason as every RC oscillator oscillates--for the tuned feedback network.
Note that for low distortion the open-loop gain of the opamp needs to be high at the frequencies of the harmonics, not at that of the fundamental.
Samuel
Old 26th December 2012, 12:41 PM   #1318
KSTR is offline KSTR  Germany
KSTR's Avatar
Adding to Samuels post, have a look here : www.ti.com/lit/an/sboa015/sboa015.pdf , a very good app note by Burr Brown "mastermind" Jerald G. Graeme.
There comes a heading somewhere "Phase only matters at the intercept" which took me quite some time to understand and accept. Like many, I've always thought not dipping below 45deg phase margin at all frequences of the OLG is a criterion for stability but it's not, more like only when you need the opamp/composite be stable at any arbitrary gain setup which is flat at the intercept OLG point. For a fixed gain design, though, the phase can dip down to any value as long as it comes back and hits the OLG with its phase no more than ~120° behind the OLG phase (for a ~60deg PM)
I then actually built -- deadbug style -- a variant of his circuit of fig.9, low gain inverting with noise-gain comp (50dB), using two 5534's with 33pF comp each. OLG (EDIT: No, Loop Gain) Phase now certainly must have crossed though 180deg at two points somewhere below intercept, given the additional pole from the noise-gain comp. No sign of instability was seen and the distortion performance was really good. Overload recovery was nasty, though...
Old 26th December 2012, 01:21 PM   #1319
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Christophe Basso explains how to think about loop stability: http://cbasso.pagesperso-orange.fr/D...y%20factor.pdf
Old 26th December 2012, 04:36 PM   #1320
Samuel
I wasn't suggesting that the op amp must be unstable to oscillate. I meant D.E. tuned the the sections to manipulate the GM and PM. He did illustrate this in his write up on the oscillator.
Well yes it makes sense that we only need high feedback gain at harmonics. If we consider a network like a bridged T, a passive notch network placed inside a negative feedback loop creates a band pass filter at a very high Q. There is little to no negative feedback at resonance since this is a high impedance state therefore we have open loop gain at Fr. What ever that is at a particular Fr.
Then it stands to reason if we use a second amplifier to provide some positive feedback to the tuned network to sharpen up the shoulders, we should see better 2nd and perhaps 3rd H results. We can do this with a Twin T notch network or a bridged T. This maybe an improvement to the single amplifier oscillator. If we pull up some 9dB at 2nd and 4db at 3rd or what ever it may be. This might be easier to do than tackling a composite arrangement. Is it more gain that we need for better distortion performance or just better use of it?
It also stands to reason then that 'high Q networks provide lower distortion' is a myth.
The lower Q networks provide more negative feedback in and around the fundamental. So there is no concern for the loss of Q by sharpening the shoulders of a network by whatever means. It just adds to the complexity.
I will read these articles mentioned. Composite amplifiers are one thing I've haven't had much success with stabilizing.
David.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
