Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 17th March 2012, 10:51 PM   #121
davada is offline davada  Canada
Hi PChi,
Lt has some excellent rms to dc convertors that extend up to 500KHz.
Take a look at the LTC1968. I have some of these and they are very good.
David.
David.
Old 17th March 2012, 11:00 PM   #122
coluke is offline coluke  Italy
Hi Davada,
ARTA's dual-channel FR mode (driving an EMU0202/0204) is indeed one of my favourite tools, and I've been using it to test my home-made notches for quite a long time. The problem with this direct method is that even at its best resolution (which is 44.1kHz SR, 131072 acquisition length - about 0.3Hz), I did never manage to get the actual depth of a high-rejection notch, the only way to reliably do this being fixing input frequency and then fine-tuning the notch itself. The -3db bandwitdth of a >60db Q bandpass filter is about 1Hz or less @ 1kHz, so I never even tried this method for determining the running Q of a generator- with barely 3 experimental points in range of interest you're likely going to underestimate the actual output level at the fundamental...; nevertheless it's an estimate I'm interested in, so I've decided to give this method a try - it actually seems to work fine: I've got a Q value around 63dB @ 1kHz, 20Vpp out, quite load independent up to 1.5kohm load, which seems actually in very good agreement with my previous - indirect - estimates.
As far as the ARTA's frequency compensation feature, I did have the same idea , and made a few tests a few months ago or so, either with ARTA itself, or importing data in MATLAB and letting it do all the math. This method actually works pretty well, failing only to provide accurate results in the vicinity of the frequency the notch is tuned to, but it doesn't seem to be a real issue since we are mainly interested in the level of the harmonics. One major advantage of this technique is that you can drive a simple passive twin-t notch at a pretty high level to extend the dynamic range of your spectrum analyzer (ie your soundcard) and let ARTA (or Matlab) do the boring task of automatically compensate for its far-from-flat response - a 20Vpp-0.0001% THD sine has harmonics in the -100dBv range, something an EMU0204 will catch smoothly.
If you don't want to play with active notches and the issues related to achieve high selectivity and good flatness and high acceptance and low THD and low noise and ..., well, this could be a nice alternative.
Ciao,
L.
Old 17th March 2012, 11:13 PM   #123
Originally Posted by PChi View Post
I really need to produce a Rev 0.2 PCB to tidy up the changes and remove some of the excess features to make the PCB smaller.
It looks very nice nevertheless - is it your APF generator with a T&H/S&H peak detector? Can you tell us some more about its architecture?
Ciao,
L.
Old 18th March 2012, 12:27 PM   #124
PChi is offline PChi  United Kingdom
Ciao,
L.
Hello Ciao,
Thanks for the complements. Yes it is based on an APF (All Pass Filter) generator with an (S&H) Sample and Hold controlling a multiplier.
I'm still playing with the circuit. I will attach the schematic and board layout when I can work out a way of attaching a KiCAD schematic.
I have just bought 'The Design Of Active Crossovers' by Douglas Self which includes some interesting measurement results on the LME49990 which shows that the distortion in the voltage-follower mode (gain, Av = 1) with 2 kohm source impedance is poor beyond about 10 kHz. I have used the LME49990 based on the data sheet claims and need to investigate further.
It's never going to be as low distortion as a fixed frequency Oscillator.
Hello David,
Thanks for the suggestion to look at the Linear Technology rms to DC converters. I think that the choice between the Analog Devices parts and the LT parts isn't clear. If I get around to designing a new Notch Filter board I will look closely at the compromises between the two types.
Old 18th March 2012, 10:27 PM   #125
Hello Ciao,
Hello David,
I thought you were complaining about your RMS detector.
David.
David.
Old 18th March 2012, 11:49 PM   #126
SoNic_real_one is offline SoNic_real_one  United States
Hello Ciao...
That's not his name, it is an italian salute
His nick is "coluke", signed "L" - probably from Luca (italian/romanian for name Luke).
Old 19th March 2012, 12:31 AM   #127
Yeah Sonic is right - didn't notice that PChi was referring to me as 'Ciao'.
L.
Old 19th March 2012, 01:08 AM   #128
I was looking into this thread for some ideas for a generator.
My options are either the wien bridge like in the Linear App Note43 (fig48) or the schematic from the first post with a proper integrator in the detector stage (easy to fit).
Low noise OpAmps are easyer to find this days...
Old 19th March 2012, 10:59 AM   #129
Sonic, I'd go for a SVF topology; if you want to try something as simple as a Wien Bridge but with far better out-of-the-box performances you can go for a HP239A clone - even in its original form (2 opamps in the Bridged-t generator plus an output buffer) it is capable of quite amazing THD figures. At present I'm playing with a slightly more complex experimental version of it employing a full-wave peak detector and OPA2134 in place of the orginal Harris opamp, and it's impressive to see how well it works.
L.
Old 19th March 2012, 12:03 PM   #130
L.
Hello Coluke,
Thanks for pointing out my error and please forgive my ignorance. I admire anyone who has learnt a another language because I have tried in the past and failed.
You are right David I was complaining about the RMS detector.
I listed the rms to DC converter that I used because that influences the measurement bandwidth and so effects the thd result.
Just for information for other readers the AD536A bandwith for 1 % error is specified as 120 kHz with an input signal of 1 V rms. It drops to 45 kHz with 100 mV. The LTC1968 has superior bandwith especially at lower signal levels but being digital goes a bit funny at low signal levels.
I chose the All Pass Filter Phase Shift circuit becaue the gain doesn't change much with frequency adjustment when using an un-matched dual gang potentiometer. Less that 1 % with a bit of tweeking from 10 Hz to 100 kHz. Also there is an almost 90 degree phase shifted (depending on component match) signal to drive a zero crossing comparator to control a Sample and Hold. Giving a low ripple control voltage.
I think that the issue with a Wien bridge is that the gain does vary with frequency because of component mis-match which the variable gain element has to compensate for. The Linear Technology AN43 circuit uses an LDR. In my experience the Silonex LDR based Optocouplers aren't very linear, others may be better. As the frequency is varied the Distortion trim needs to be adjusted to cope with the mismatch of R1 and R2 which isn't practical. It's also difficult to stabilise the amplitude control loop with the filtering causing problems. If the frequency is fixed then the circuit or the later configuration AN132 is good.
I think that the State Variable Filter topology is good for fixed frequency but I think that gain varies with oscillation frequency due to dual gang potentiometer mis-match so I believe that it's dificult to come up with a low distortion variable frequency version.
I guess that all this proves that it's suprisingly difficult to make a variable frequency low distortion oscillator.
Regards Paul
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright ©1999-2017 diyAudio
