Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 19th December 2012, 06:27 PM   #1231
davada is online now davada  Canada
Originally Posted by RNMarsh View Post
Chicken ! I dont have those same devices but I think I might have some J111 if they are same/similar? I'm not sqeemish about cutting a trace - isnt a problem for me. I dont faint at the sight of a cut. Have No Fear. -RNMarsh
Well if there is promising results I don't have a problem. One thing at a time though.
I did the dual Jfet late night. I have another idea to try similar to the degeneration but active.
Or you could call it active degeneration.
David.
Old 19th December 2012, 08:30 PM   #1232
john curl is offline john curl  United States
john curl's Avatar
app note
"Condemnation without Examination is Prejudice"
Old 19th December 2012, 08:33 PM   #1233
john curl's Avatar
more app note
Old 19th December 2012, 08:34 PM   #1234
john curl's Avatar
and more:
Old 19th December 2012, 09:18 PM   #1235
richiem is offline richiem  United States
richiem's Avatar
John -- can you make those into a PDF and zip it, so we can download the whole thing at once?
Dick Moore
Old 19th December 2012, 10:12 PM   #1236
john curl's Avatar
No, I can't, sorry.
Old 20th December 2012, 12:10 AM   #1237
1audio is offline 1audio  United States
The note mentions that the lowest distortion is when the fet is most on and has the lowest Vds. The next real question is how much gain range is necessary for an AGC to stabilize an oscillator and what tradeoffs are there? I believe a range from 1.1 to .9 is more than enough (may take a while to settle or start). If Rds on is the important factor 20 Ohm FETs are quite available. Lowering the impedance of the circuit at that point would only help anyway.
Demian Martin
Product Design Services
Old 20th December 2012, 12:52 AM   #1238
More gain may be needed to get the oscillator started and to it's reference level.
There is no reason why we could'nt switch from a start-up to a run mode.
Fast response to low distortion as it was done in the ST1700 series.
My experience has been that just enough gain for running at say 1KHz is insufficient for start up at other higher frequencies. The gains are different at 100, 1KHz 10KHz and 100KHz. The oscillator may run in a narrow gain range but it start.
David.
Old 20th December 2012, 01:07 AM   #1239
I'll scan that portion of the ST1700 oscillator this evening and publis it. They used both an LDR and a FET. Get all options involved. . .
Demian Martin
Old 20th December 2012, 02:16 AM   #1240
I used to have one of these. I have the manual in PDF for the 1700B.
I can post it if you want to save the time scanning it. If the files are small enough to post.
Up to you.
David.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright ©1999-2017 diyAudio
