Low-distortion Audio-range Oscillator Low-distortion Audio-range Oscillator - Page 118 - diyAudio
Equipment & Tools From test equipment to hand tools
Old 16th December 2012, 04:19 AM   #1171
1audio is online now 1audio  United States
David:
First here is some good background on how the linearization works: http://www.vishay.com/docs/70598/70598.pdf Looking at HP's schematic the linearization is ac coupled (60 pF cap) which means it changes with frequency. Possibly both a trim for DC and a cap coupled (at the wiper) trim for ac in parallel. The sketch shows what I am thinking- R4+R2+C1 are the ac (hf) distortion trim and R3 + R1 are the DC (LF) trim.
Attached is the circuit from the KH4400. It really works but you need something like the 725 to really use it. The trimmer really nulls the 2nd harmonic right out. It takes feedback from the voltage across the fet in positive phase along with a small negative phase (trim resistor) which seem to find the right balance. There are some caps for HF compensation.
Demian Martin
Product Design Services
Old 16th December 2012, 05:40 AM   #1172
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Hi Demian.... there is an R and C in series across the FET (gate to Drain) as well as in series with the gate. The C value is large --60 Mfd.
I had put a trimmer in place of each R and adjusted. It helped but not a lot and couldnt null out the H2. Changed the 60Mfd to bipolar as well. Maybe a more elaborate network as you show with J1.?
Right now, if i use the X1K range (optimised for that range) and adjust the freq dial from 1 to 10.... It'll cover most freq of interest; 1KHz to 10Khz. The ShibaSoku monitored the 339A generator shows good ageement with the 339A analyzer.. even though the levels are all small and in the lower 10% of the meter range. Good meter.
I get same reading value on both instruments meter displays. Nothing measurable above H2, btw: HP339A at 1KHz is .00023% thd+n and 10KHz it is .0008% thd+n. This is almost usable. I need .0001 or better. I havent replaced some opamps which could further reduce the THD. [And all filters IN on 339A analyzer.]
I can now try the FFT on the 725 analyzer using the .00023%, THD, 1Khz freq. 725 already told me its all second harmonic, though. The 725 will display the level of 2,3,4 and 5th harmonic as well as the total. Will measure Victors osc as well. Thx-RNmarsh
Old 16th December 2012, 06:02 AM   #1173
davada is offline davada  Canada
[QUOTE=1audio;3286832]David:
Yes this is exactly the problem. You can see it monitoring the control voltage on the gate.
It changes with range and frequency.
I can use the summing amplifier which drive the jfet gate in the AGC to sum the signals in.
I'll give it a try.
David.
Old 16th December 2012, 06:12 AM   #1174
Hi Rick,
Try working the 'Amplitude Adjust' R30 along with the distortion trim.
David.
Old 16th December 2012, 05:21 PM   #1175
RNMarsh's Avatar
Default 4 zero's and a 2 --
I have a variable twin-t filter and I applied it to the 1KHz signal from the 339A. I tuned the H2 out and now the distortion is -- .000025% (4 zero's) ! [maybe mostly noise.. have to check with FFT]
Though it will be great to have it all done in one box. I'll follow on further lowering; espec that H2. Thx-RNMarsh
Old 16th December 2012, 05:49 PM   #1176
The B&K is also lowering the 3rd and up harmonics (and the fundamental) so its not clear what you are getting. The 725 will go down to .00001% with the ag15. Too many zeros and its easy to get confused.
To tweak the distortion of the HP just select H2 on the 725 and tweak for the lowest.
Attached is a plot of the distortion from the AG16 measured with an AK5394A demo board. All of the harmonics are -124dB or below. This is probably the limitation of the AK5394A since the 725 indicates much less distortion.
I think -120 dB and below for harmonics becomes a point of no real return for effort. No analog recording system ever came close and this is possibly the best digital today.
Demian Martin
Old 16th December 2012, 05:58 PM   #1177
RNMarsh's Avatar
I factored that all in. The input level is adjusted to be at 100%. Some 3rd plus may be attenuated... dont care as it and the other higher H are Much lower than the H2. Besides, thats all for the better.
Now, I'm back to the same situation as before.....but now with the 725; On the lowest range and at 10% of the low end of the meter. Wonder if I can get another -20dB somewhere. One more zero. -Thx RNMarsh
[just kidding]
My interest is in being able to accurately measure my own amplifier designs which are very low analog. Now I can tune them for lowest Harmonic distortion. I want to be at least 10-20dB better than my amp circuits.... which are already pushing the -110 (or more) mark in practice (not sim).
Old 16th December 2012, 07:06 PM   #1178
RNMarsh's Avatar
How is that residual output port on the 725 work? Something seen at near 500hz -- whats that? Thx-RNM
Old 16th December 2012, 07:32 PM   #1179
The fundamental is converted to something around 415 Hz I think. Its harmonics are in the output jack with the fundamental removed. The noise is also removed. The FFT will show you.
I have been looking at the simple FFT displays on e-bay to see if one would work for this. No need for exotics.
Attached is a snapshot I took of the distortion output measuring Victors oscillator. The tall peak is the 2nd Harmonic. 2-10 are shown in a bandpass to 5 KHz. This does not change with input frequency. You can also sync to the trigger output and see phase relationships.
Demian Martin
Old 16th December 2012, 07:47 PM   #1180
Default Unbelievable. Another small mod
Just when I thought it was at it best.
You can just barely see that 2nd sticking it head out of the noise.
I just can't seem to shake that 4th H though.
David.
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2017 diyAudio
