Equipment & Tools From test equipment to hand tools
Philips PM3215 Scope Tantalum Capacitor Upgrade
Old 27th January 2012, 06:45 AM   #11
Mooly's Avatar
Originally Posted by techbiker View Post
Mooly, what should I be looking for if I measure the scope with its own probe? I've never checked rails for ripple.
Also, I double checked and the 4700uf 40v capacitor is listed as an electrolytic tantalum in the service manual. These do exist, but they are very expensive.
Any regulated (stabilised) rails should be virtually pure DC.
So with the scope AC coupled and the probe on the appropriate rail you should see only a minimal AC component present. Perhaps as low as a couple of millivolts. Somrthing like the 4700uF cap (and I'm guessing without seeing the circuit) sounds like a main reservoir cap before any regulators and so a couple of volts of ripple may be present here.
All test like this assume that the negative end of the cap is at ground potential (or positive end of cap in the case of negative rails).
Don't connect the ground of the probe to any point internally in the scope. If a cap seems to have a large ripple component then measure on the other end as well. It may not be at ground potential.
I think tbh the scope will be performing to spec... so don't break it
Old 28th January 2012, 01:37 AM   #12
techbiker is offline techbiker  United States
Thanks for the recommendations. I will test the scope and see if I could benefit from new capacitors.
The build quality on this scope is actually pretty good. It's amazing that working test equipment from the 60's-80's is still floating around!
I called up Philips and they had no idea what the "Scientific and Industrial" division was lol. I then called up Fluke and the VERY helpful guy on the phone flat-out refused to support their older equipment.
It's a good thing this forum exists, that's for sure!
Philips PM3215 Scope Tantalum Capacitor UpgradeHide this!Advertise here!
Tantalum capacitor markings rendisha Parts 4 29th June 2012 05:46 PM
Thinking of getting this Philips scope Marcel_D Equipment & Tools 14 25th December 2010 05:52 PM
Tantalum capacitor polarization? Puffin Chip Amps 13 9th September 2008 04:04 PM
PM3267 Philips scope helicopter3 Vendor's Bazaar 2 24th April 2007 10:22 AM
Philips PM3217 SCOPE Manuals Jim Mullally Parts 3 27th May 2006 06:05 PM
Copyright ©1999-2017 diyAudio
