Equipment & Tools From test equipment to hand tools
How to use an oscilloscope
Old 14th September 2003, 03:07 PM   #1
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Question How to use an oscilloscope
Hi everyone,
A friend just bought a 1970s oscilloscope for £5 - partly, he was thinking of me and my hi-fi habit!
Neither of us really have much clue about how to use it properly though. Can anyone explain the basics for trying to look at power supply line noise and ripple, or anything else that is useful to a DIYer/tweaker?
Alternatively, can you point me to a good BEGINNERS guide?
Do I need proper probes for it? It didn't come with any and I am using standard multimeter ones...
The 'scope itself is quite large, uses valves, and has two sets of inputs on the front. I can/will post a picture of it shortly.
I put it onto my homemade 5v psu and have managed to see a sort of lumpy sine-wave - is this AC ripple?
Thanks for any suggestions,
-Simon
Old 14th September 2003, 03:39 PM   #2
SimontY's Avatar
Here is a pic, showing what I found on my 5v psu. I guess the waveform shows AC ripple - I must need more than 5,000uf of smoothing!
How do I go about seeing 'noise'/RF/whatever on the line?
Might the scope not be sensitive enough for this??
-Simon
Old 14th September 2003, 03:40 PM   #3
SimontY's Avatar
err, picture...
Old 15th September 2003, 05:44 AM   #4
faustian bargin is offline faustian bargin  United States
i'm in kindof the same boat as you are. just got a used scope, want to figure it out. (if anyone knows where to find a cheap/free manual for a tek 2215a, lemme know...)
i just found this page on tektronix's website, it should help out a great deal. plus, it's in nice printable pdf format.
XYZs of Oscilloscopes
dig in... (or if you're the corny type: 'scope it out.')
/andrew
Old 15th September 2003, 06:18 AM   #5
Jennice is offline Jennice  Denmark
Hi guys,
I'm quite used to oscilloscopes. If you still need a hand after going through the guide in the link (in the post above), let me know
Jennice
btw.: To me this doesn't look like ordinary ripple... more like a scope picking up as an antenna (no good connection). Could you please post a new pic of that line distortion, with a description of your horizontal time axis (ms/div) and sensitivity (vertical, mV/div)
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 15th September 2003, 11:32 AM   #6
SimontY's Avatar
Andrew,
Thanks for the link, I will check it out when I get home tonight...
Jennice,
I will check what settings I used when I get home, again
I think I had sensitivity on 5volts, but I'm not sure, I'll check. Not sure about the time setting... I'll look. Btw I don't think I get anything like that when the probe(s) aren't connected, I think it's somehow coming from my power supply. Why do you want a *new* picure of the distortion? Just as a repeat, for consistency?
Cheers guys,
-Simon
Old 15th September 2003, 11:46 AM   #7
No, it should only be partially for reproduction/reliability. ItÝ's more the point that it doesn't look like the ordinary PSU hum/niose (unless you're working with a hard load on your PSU).
Old 15th September 2003, 11:49 AM   #8
Ooops... by the way...
You CAN risk getting something like that on your scope if one terminal (active) is connected. In that case, you can experience that the probe acts like an antenne, picking up 50 HZ field from nearby sources, such as your PSU leads or the transformer itself.
Jennice
Old 15th September 2003, 11:54 AM   #9
jackinnj is offline jackinnj  United States
jackinnj's Avatar
if you have a rainy afternoon when you can't go out and play, spending time on the TEK website will prove an educational treat --
one important thing on scopes -- don't skimp on probes -- no, you don't have to spend $300 on a probe, but a $40 10X/1X probe will make your measurements more reliable and understandable.
Old 15th September 2003, 12:46 PM   #10
Jacki,
I agree that probes are a factor, but then again, the submitted scope picture had (as I understood it) a 5 V/div scale, and looking at a (hopefully) low impedance. This should, if everything is hooked up OK, provide a very low sensitivity to noise.
Btw., the scope does not seem to have BNC (shielded) input...
Jennice
How to use an oscilloscopeHide this!Advertise here!
oscilloscope kit henryr Equipment & Tools 5 18th June 2009 10:08 PM
Need help with oscilloscope error0 Equipment & Tools 2 6th April 2008 01:22 AM
Oscilloscope XTAL Parts 0 18th March 2005 05:05 AM
PC or USB Oscilloscope owel Parts 9 31st March 2004 08:55 PM
oscilloscope Kilowatt Digital Source 12 22nd January 2002 12:30 AM
Copyright ©1999-2017 diyAudio
