Equipment & Tools From test equipment to hand tools
Workbench Top
Workbench Top
Old 23rd December 2011, 05:12 PM   #11
Lavcat is offline Lavcat  United States
Lavcat's Avatar
Well, my top came, but I can't lift it. I certainly cannot get it up the stairs.
Old 23rd December 2011, 05:33 PM   #12
woody is offline woody
Workbench Top
Why wouldn't the raw maple be ok as is ? I would think it would not be subject to
static build up.
Old 23rd December 2011, 09:10 PM   #13
thaumaturge is offline thaumaturge  United States
thaumaturge's Avatar
Static accumulates on non-conductors. No path to permit them to equalize.
Doc
Noli timere problematum affigit
Old 24th December 2011, 05:38 AM   #14
Lavcat's Avatar
A strong friend was kind enough to come over tonight and set the workbench top on the table for me. It is quite a slab of wood. It was all he could do to get it up the stairs. Sadly he found the beer too bitter.
Next project is to oil the surface before I start using it. I have to figure out the best kind of oil. Maybe mineral oil?
I got the surface for machining and electronics projects but I'd really love to use it for baking bread. Probably should not try to use it for both however.
Old 24th December 2011, 05:47 AM   #15
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Don't do it! Mineral oil will never "dry". Consider an oil that will catalyze. You want cross-links to form in the oil to provide more durability and seal the surface. For bread baking or any contact with food try this:
Buy General Finishes Salad Bowl Finish Pint at Woodcraft
"Salad Bowl Finish" is the same material I use on cutting boards. Get the pad sander out and work through the grits up to 320 or 500...then oil...several coats.
Old 24th December 2011, 07:35 PM   #16
Lavcat's Avatar
Thanks for the URL. I followed a lot of the links on Woodcraft. I don't see why I would want a drying finish vs. a non-drying finish for the top. I checked the manufacturer's site and they say to use mineral oil. The top is probably going to get machine oil splattered on it anyhow. I have a Wusthof branded product that's a mixture of oil and beeswax which has worked nicely on some kitchen surfaces (and on my guitar neck and bridge). I am still thinking straight mineral oil will be the best finish for the top though, and mineral oil is how it was treated when it was manufactured.
While I am serious about my bread, and would love to have a surface like this for baking, I was joking about dual purpose. No one would want swarf in a sandwich, not to mention little bits of solder.
Old 24th December 2011, 10:19 PM   #17
Lavcat's Avatar
Update: about forty years ago I bought a bottle of mineral oil. I thought it was enough to last. Well, I found the bottle... lying on its side. (Note to self: do not store mineral oil bottles on their sides.) It being a nice day, if a bit chilly, I hiked out to the drug store and came home with a brand new quart of mineral oil. Lovingly I rubbed most of it into the maple using my bare hands. Most sensual experience I've had in a while -- probably since the night a few weeks ago when way overtired I fixed a pizza and confused the extra virgin olive oil for the Dawn detergent. I jest not. Really nice for the cuticles.
Got me wondering what would be the best oil to use for tonearm anti-skating fluid, but I realize this is not the forum.
So the top is oiled. I could not reach all of the underside, as I cannot lift the thing. I hope that will not cause a future problem with warping. I'm going to let it sit overnight before doing more with it. I must say the wood looks really pretty, and you should feel my hands!
Old 25th December 2011, 08:48 PM   #18
Lavcat's Avatar
Default There is a downside
Being concerned about the dire warnings of warpage if all surfaces were not oiled, I (with some difficulty) lifted the top up onto its rear edge to expose the bottom. I knew the bottom was unfinished. What I did not know was that there were four metal staples sticking out. These destroyed the cheap but otherwise attractive laminated surface on which the new top was mounted. And could have done a job on someone's body parts, e.g. mine.
Boos has been in business long enough that I would have expected better. I am not a fan of overly detailed safety warnings, but a simple note to beware of the sharp staples would have been appreciated. Particularly as there was a two page sheet warning about proper oiling. Is it just me, or would others expect a wood product to come with staples in it?
Nonetheless I carefully oiled the bottom as instructed. But I did *not* use my bare hands.
Workbench TopHide this!Advertise here!
What's on your workbench ???? cnctooltek Equipment & Tools 308 22nd November 2011 10:31 PM
Workbench safety practices? Stormrider Equipment & Tools 3 3rd August 2008 06:08 PM
Help Setting up an electronic workbench JMB Parts 6 8th December 2007 05:32 PM
Electronics workbench = garbage sndscietist The Lounge 1 3rd July 2005 08:56 PM
Electronics Workbench 4 opamp sim bug. Circlotron Everything Else 0 12th April 2004 01:47 PM
Copyright ©1999-2017 diyAudio
