Triple outputs 100W Laboratory PSU -- A new DIY project .
Hello Carpin,
I design the transformer because you can't find already build transformer with your own specs !
Designing and building it is not a big problem for me.
I don't think that the case will need a fan. The enclosure is in extruded aluminium and it's thermal impedance is good.
Of course, only final tests at maximal power will verify this.
Regards.
Frex
Hello,
The full design is well advanced and the flyback transformer is now soldered and tested on the final board, and fully functional.
I have done many tests on the flyback, including measurements of efficiency vs Pout and vs Vline.
I have tested the short circuit and open loop conditions and thermal behaviour of power parts.
I will post complete graphs results tomorrow.
Some little modifications has been done (parts values) to optimise it.
Front panel is now also drilled.
You can show the design progression on pictures below.
Frex
Hi Tazzz,
Thank you for your comments.
These measurements are made on the flyback outputs, not final PSU outputs.
But yes, i will perform others measurements on the real PSU outputs, like ripple voltage and a 0.5A/1.5A load step transient response.
That's not yet finished ! :)
FRex
Hi all,
The PSU project is still in progress. The front panel has been drilled.
No big issue has been encountered during mechanical mount.
The green plexiglass of the leds displays is too dark, i must find another.
I've also started to do some quick noise measurements, that show about 20 mV with
a purely sinusoidal profile.
I must d build a serious measurement setup to do these measurements with good confidence.
Frex
Hello all,
I've finally ordered a new set of drilled and engraved front and rear panel of the PSU to Schaeffer-ag.
I discover their services, and cost is very reasonable.
So, i wait these new panels, with color marking for a beautiful finishing.
I have find also another green windows that give a very good display result.
(i use a translucent green CD cover ! :) ).
I've also made some tests, connecting PSU outputs in many serial configurations, and all pass successfully.
I don't have much time right now to perform all needed test, but i'll post any results as they become done.
Maybe, if some DIYers are interested to build this project, i could open a wiki page to summarize infos about it and create a list of potential builders.
Please, give me your feedback about that...
Regards.
FRex
Hi rikkitikkitavi,
Thank you for your interest.
The three zener diodes D14,D19 and D23 protect the TPS5450 feedback inputs from over-voltage. This is need because the OPAMP that drive these inputs is supplied from the buck input voltage (~22Vdc).
Normaly, i will receive my newly drilled and engraved panels from Schaeffer this thuesday...
That's cool....
Frex
Hi all,
I've receive as expected my new front and rear panel from Scheaffer today.
It's the first time i use their service and i'm very impressed.
It's a very clean job as you can show below.
I will mount them tomorrow and new pictures will come soon.
Regards.
Frex
Hello all,
The new panel has been mounted now, they give a professional look of the PSU.
You can see the results on some pictures below.
-1 - Front view, off state.
-2 - rear view.
-3 - front view, on state.
-4 - Front view with Metrix AX322 PSU for size comparison.
(The EPSUX3 is also very lighter than AX322!).
Before to terminate this design, i must optimize the current regulating loop that oscillate in some conditions. That will be only change some parts values.
Then after that, doing a complete and accurate measurements table for each output.
I've weigh the PSU (without cord) and it's only 1.2kG (2.64 pounds).
I hope to open the new wiki page for the PSU project very soon, and starting to take the name of interested DIYers to get the PCB.
Because i understand that building the flyback transformer can be a barrier to build this PSU project, if enough buyers are interested i could try to order the transformer to a manufacturer.
Frex.
(I've already start a new project, a power amplifier for my squeezbox Touch, but you be informed about it later. ;) )
