Equipment & Tools From test equipment to hand tools
Another Fluke DMM problem.
Old 20th November 2011, 05:48 AM   #1
samer0214 is offline samer0214  United States
Default Another Fluke DMM problem.
My Fluke 11 is giving erroneous AC & DC voltage readings on the high side by about 70%!! AC voltages such as 120 (taken at an outlet) are reading at 205v, and DC voltages that should be 8.4 volts are measuring at 14.50 (70% over)!
I called Fluke and they said the meter is shot and suggested a replacement with a core exchange. Needless to say it was too expensive, and I would rather try to repair it myself if it is repairable. I downloaded the service manual and hopefully with this forum's help, I can repair it.
Any ideas as to what could be wrong? What should I be checking? Please let me know.
Samer
Old 20th November 2011, 07:00 AM   #2
Francec is offline Francec  Australia
Banned
As I understand it, Flukes are, largely, based on very big ICs so the advice may well be correct. I would like to be proven wrong being an owner of a Fluke DMM but I doubt it.
Old 20th November 2011, 08:24 AM   #3
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
did you replace the battery yet?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 20th November 2011, 08:49 AM   #4
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
It's a long shot but try cleaning the switch contacts.
Old 20th November 2011, 09:01 AM   #5
And you would be right. The Service Manual lists two of them, but lists the P/N for only one of the two, so I assume it is the only one that is replaceable. I will open it up tomorrow and check.
I haven't, but as a matter of fact, the low battery indicator is on. Could the problem be so simple as to only require a battery change? I'll let you know if that solves it.
Samer
Old 20th November 2011, 09:07 AM   #6
You can buy a new Fluke on E-Bay for less than the cost of the IC. As it will need calibrating afterwards its hardly worth repairing it.
Old 20th November 2011, 09:24 AM   #7
Default Problem Solved!
I couldn't go to sleep after I read the post about swapping the battery out (it's after 2:00 AM on the West Coast), so I changed it, and that took care of the problem! Thanks Tony!
How could the Fluke tech I spoke with on the phone not ask me about something like this? Their 1st and only answer was that the DMM had gone bad and needed to be replaced. Simply amazing!
BTW, neither of the ICs is serviceable/replaceable. They are big, and they are soldered to the board. So much for that idea.
Samer
Old 20th November 2011, 09:26 AM   #8
SUCCESSFUL RESULT - That is the aim of the game.
Old 20th November 2011, 10:36 AM   #9
TonyTecson's Avatar
i have other dmm's that exhibit this symptoms when battery is low....battery is nominally 9 volts, at 7 volts these symptoms appear....
i also has this problem with some segments on the lcd not lit......solution is to clean the contacts with cotton buds dipped in rubbing alcohol, both pads and lcd contacts.....in case you encounter this problem....
Another Fluke DMM problem.Hide this!Advertise here!
Fluke 8840A bench DMM for sale grenert Swap Meet 2 9th May 2011 04:26 AM
Fluke 175 Dmm ? semi932 Equipment & Tools 5 18th May 2010 01:25 AM
Get a Fluke DMM ThSpeakerDude88 Parts 107 21st August 2007 12:40 AM
FS: Fluke 87 DMM w/ case, lead, manual gengis Swap Meet 5 20th September 2006 05:09 PM
Fs Fluke 77 Dmm powertriode Swap Meet 2 22nd July 2006 07:52 AM
Copyright ©1999-2017 diyAudio
