Equipment & Tools From test equipment to hand tools
Heathkit audio Wattmeter
Old 16th November 2011, 07:21 AM   #1
ArcticBreaze is offline ArcticBreaze  New Zealand
ArcticBreaze's Avatar
Default Heathkit audio Wattmeter
Hi there guys Picked up a Heathkit AW_1U watt meter, but its got no instructions with it. anyone got any? The schmatic is all over the net but actual operators manual I canna find. all i really need to know is what sort of signal to feed the amp to get a realistic answer. (i was just blowing harp thru my 5e3 and peakin at 30 watts output, I dont think thats quite right lol, Hit 50 on ma Bassman).little help please.
Old 18th November 2011, 04:11 AM   #2
thaumaturge is offline thaumaturge  United States
thaumaturge's Avatar
Heathkit Schematic Diagram Archive has both AW-1 & AW-1U. The schematics look identical. The AW-1 has a spec sheet with it that lists 25W continuous or 50 intermittent. I'd go less than 25, as the load resistors are 24. Figure out what volts into 8 ohms equals 20 watts then set that output using RMS voltmeter. (Feed an oscillator into the amp, probably set to 1000 Hz) Adjust cal pot for 20W. Check at 10Khz. Adjust best compromise setting.
That's my best guess. (How I'd go about it.)
Doc
Noli timere problematum affigit
Heathkit audio WattmeterHide this!Advertise here!
Heathkit AG7 Audio Geneator engels Equipment & Tools 19 1st January 2018 02:15 AM
Heathkit Pro Series Audio Rack-I want one eds65gto Swap Meet 3 15th December 2015 08:23 PM
Heathkit AG-9A audio generator schematic !!! aldovan Equipment & Tools 4 15th November 2008 03:03 AM
Dx Led Wattmeter, it can be usefull, and you can modifie and put your name on it destroyer X Solid State 20 7th September 2005 11:23 PM
Wattmeter TedPolzin Solid State 15 17th December 2002 04:12 PM
