Equipment & Tools From test equipment to hand tools
Voltage Logarithmic convertor
Old 27th October 2011, 04:43 PM   #1
Atilla is offline Atilla  Norway
Default Voltage Logarithmic convertor
I saw this while looking into how logarithmic amplifiers work:
A Novel Voltage-to-Voltage Logarithmic Converter with High Accuracy
Has anyone implemented anything similar? The usual log amplifiers seem to require a bit complex thermal compensation, while this idea looks fairly stable.
I need audio signal in, log-scaled voltage out and I've started getting very confused in how to do it. I don't need high-frequency operation that much, neither perfect precision, but I've no idea how bad the standard-issue log amplifier really is.
Old 27th October 2011, 06:16 PM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
What are you attempting to accomplish?
Audio input and a log d.c. output?
Frank
Old 27th October 2011, 06:28 PM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
http://www.analog.com/static/importe...ets/AD8310.pdf
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 52 pcb's in order. 41 paid.
Old 27th October 2011, 07:50 PM   #4
Yes, exactly that Frank.
Thanks peranders, I just saw that IC and a Maxim IC an hour after I asked. The MAX4206 looks hard to source, but the AD should be easier to find.
Old 27th October 2011, 08:28 PM   #5
I found an AD8307 here, it looks like that'll do fine.
Old 28th October 2011, 08:53 AM   #6
Frex is offline Frex  France
Hello Atilla,
Maybe this project could interest you, it's a DIY RMS voltmeter with DC log output
using the AD8307 IC.
Frex.
Old 28th October 2011, 09:43 AM   #7
Thanks a lot Frex, this will help me a lot, indeed. And by the way - great project there!
Old 28th October 2011, 02:59 PM   #8
In the case of you would want to build it, i have some bare PCB of this
project available for sale.
Frex.
Voltage Logarithmic convertorHide this!Advertise here!
Logarithmic Amplifier Design dan_thompson87 Solid State 14 28th May 2011 08:03 PM
Logarithmic Pot. instead of linear? suicida Parts 4 23rd February 2009 11:04 PM
Logarithmic potentiometers eeka chu Parts 3 31st December 2004 01:17 PM
100K Noble logarithmic pot 2Bak Chip Amps 7 27th January 2004 10:46 PM
Logarithmic attenuation FunkyStu Solid State 4 31st December 2003 02:54 PM
