Equipment & Tools From test equipment to hand tools
Router bit?
Router bit?
Old 10th September 2011, 08:12 PM   #1
jmar is offline jmar  United States
Default Router bit?
Has anyone ever seen a specialty router bit for routing the inset edge on a speaker? (So that it will lay flush with the baffle).
I've made circle jigs and a straight or mortise bit to do it in the past, but it sure would be nice if something existed that has a roller on the bottom like a trim bit.
Obviously the roller would have to be a smaller diameter than the bit itself so the bit would cut into the material.
Such an animal exist?
Thanks.
Old 10th September 2011, 08:17 PM   #2
You know what? -- did some further searching.
A rabbeting bit ! Wasn't thinking.
Old 11th September 2011, 05:32 AM   #3
dchisholm is offline dchisholm  United States
dchisholm's Avatar
The guide bearings on many (not all) rabbeting, flush-trim, and slot bits can be exchanged for a bearing with larger or smaller O.D. This allows you to cut a wider or narrower "shelf" as needed. Some of the router-bit vendors will even sell a kit containing several bearing sizes
(My apologies if you already know this; folks who are new to routers may find it useful if they stumble across this thread.)
Dale
Old 11th September 2011, 12:04 PM   #4
whgeiger is offline whgeiger  United States
Default Backwards
Thanks.
Use a micro-fence or equivalent circle jig with your router.
Cut a wide, flat groove first (multi-pass), then cut the hole last (deeper cut).
Circle Jig Attachment Use w/ Edge-Guide - CJA - Micro Fence -
WHG
Old 11th September 2011, 12:37 PM   #5
thaumaturge is offline thaumaturge  United States
thaumaturge's Avatar
MLCS Slot Cutter Router Bits and Stackable Slot Cutter Set
Noli timere problematum affigit
Old 12th September 2011, 01:31 AM   #6
chrish is offline chrish  Australia
chrish's Avatar
WHG
I have built many speakers, and this is the best method in my opinion.
Old 12th September 2011, 02:33 AM   #7
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Remember you'll need ~4" diameter (or smaller) for tweeters. That puts the center pin under the baseplate of many routers. Some adaptation is required.
Old 12th September 2011, 07:56 AM   #8
creutz is offline creutz  United States
Depending on what router you have, you should be able to make a separate base plate for your router if you need a smaller diamater cut. I've done it both for my Milwaukee and a craftman router and it works great. Then you can just drill holes in your "new" baseplate and use a small drill bit or a nail for a center pin. A piece of plywood or MDF works great for a baseplate ..
Old 13th September 2011, 08:38 AM   #9
chrish's Avatar
I use a Jasper circle jig. Works great, no problem making holes for tweeters with diameter smaller than base plate. Jasper Circle Jigs
Old 13th September 2011, 10:38 AM   #10
Nobody seems to have noticed, but the cutter bit I linked to in message #5 of this thread will cut up to a 3/8" wide lip up to 1/4" deep around an existing hole. Just FYI
Doc
Router bit?Hide this!Advertise here!
source for a 15 degree chamfer router bit giralfino Equipment & Tools 5 30th July 2011 02:12 PM
Router bit recommendations? DualTriode Construction Tips 10 10th November 2010 02:53 AM
Choosing a router bit for plywoods cloudniner Multi-Way 9 17th April 2009 04:45 PM
cut aluminum with regular router bit? critofur Everything Else 9 16th July 2008 10:00 PM
Can somebody educate me on router rabbit bit usage? Jim85IROC Multi-Way 26 26th February 2004 04:08 PM
Copyright ©1999-2017 diyAudio
