Equipment & Tools From test equipment to hand tools
Alternate use for an LM3886 - PSRR/LineReg test set
Old 10th July 2011, 09:24 PM   #1
tomchr is offline tomchr  Canada
tomchr's Avatar
Default Alternate use for an LM3886 - PSRR/LineReg test set
Folks,
I just completed my latest piece of test gear. A test set for measuring PSRR or line regulation of a power supply. It'll source/sink several amps with a compliance of up to +/-40 V. It has an AC coupled modulation input as well as an AC coupled output monitor output. It's based on an LM3886...
It can also be used as a stereo power amp...
The BNC connectors are 5/8" (16 mm) apart. That's a bit tight. The standard spacing of 3/4" (19 mm) is much preferred. It works, though.
~Tom
Alternate use for an LM3886 - PSRR/LineReg test setHide this!Advertise here!
JL Audio 300/2 test/set bias vchhat Car Audio 8 26th June 2011 07:04 PM
Calibration of Mercury 1000 tube test set TheGimp Tubes / Valves 15 8th March 2011 03:55 AM
A Test Set for Nondestructive Safe-Area Measurements Tarzan Solid State 26 29th July 2010 03:02 AM
LM7812 Test, PSRR 60dB at 100Hz ripple lineup Power Supplies 7 6th November 2006 02:12 AM
WTB: Pierre Verany Digital Test CD set percy Swap Meet 0 28th March 2006 02:58 PM
