Oscilloscope as Spectrum Analyzer/Frequency Response Analyzer Oscilloscope as Spectrum Analyzer/Frequency Response Analyzer - Page 2 - diyAudio
Equipment & Tools From test equipment to hand tools
Old 8th June 2011, 06:45 AM   #11
gpapag is online now gpapag  Greece
gpapag's Avatar
You may build a log converter with common components ,which you may already have
http://www.national.com/an/AN/AN-30.pdf
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 8th June 2011, 11:44 AM   #12
geraldfryjr is offline geraldfryjr  United States
What Frequency range?
Old 8th June 2011, 08:20 PM   #13
gpapag's Avatar
I havenít built it.
From the pdf (page 2, left column):
Both of the transistors are used in the grounded base connection, rather than the diode connection, to eliminate errors due to base current. Unfortunately, the grounded base connection increases the loop gain. More frequency compensation is necessary to prevent oscillation, and the log converter is necessarily slow. It may take 1 to 5 ms for the output to settle to 1% of its final value. This is especially true at low currents. The circuit shown in Figure 2 is two orders of magnitude faster than the previous circuit and has a dynamic range of 80 dB. Operation is the same as the circuit in Figure 1, except the configuration optimizes speed rather than dynamic range.
If settling speed has anything to do with highest frequency, then, for Fig.2 circuit, using f =1/T, we have f= 1/0.00005sec, that is f=20kHz worst case and f=1/0.00001sec=100kHz best case
Old 9th June 2011, 04:40 AM   #14
hitachi_nut is offline hitachi_nut  Canada
I know that building your own stuff from scratch is fun and fulfilling but sometimes you have to draw the line somewhere.
Re: NS AN-30, where can you find the thermistor used in the example? Is there a reference board that you can copy to save time? Is the person that will be building this log amplifier have enough equipment and resources to validate the finished unit's operating performance?
Personally, I'm not willing to spend days, weeks and even months designing something that already existed, tried, tested and the best part of all cheap!
Not here to argue, just pointing out the obvious
Old 9th June 2011, 10:35 AM   #15
gpapag's Avatar
Not here to argue
Hitachi_nut
No problem from my part.
I just hope you didn’t take my intervening as an attempt to argue with you either.
It was only that with my metrics, 12 UKP (from RS Components) isn’t cheap.
The penalty I have to pay (and gains I may get)for choosing the cheap components route though, is well described in your response.
I have nothing to confront your solid logic.
On the contrary, to add to it, from the AD8307 data sheet
http://www.analog.com/static/importe...ets/AD8307.pdf
Fig 19, I can concur that the response time has nothing to do with freq.response.
Got me a null score here too.
Therefore, the question
Has to be answered by a knowledgeable member. Sorry geraldfryjr
George
Old 9th June 2011, 01:45 PM   #16
sameerdhiman is offline sameerdhiman  India
Audio Band
Sameer Dhiman
Old 9th June 2011, 02:44 PM   #17
AD8307 frequency range as specified on the datasheet -> DC-500MHz, not enough
Dynamic range is better than 88d B, Settling time < 500nsec
Almost everything you need to know is on the AD8307 datasheet. Analog Devices even offer samples for crying out loud. That's how I got mine before
AD8307 | Low Cost, DC to 500 MHz, 92 dB Logarithmic Amplifier | Log Amps/Detectors | Specialty Amplifiers | Analog Devices
There's also a guy on eBay selling them for <$10 shipped. There several ways to get the chip "cheaply" if look hard for it.
Audio Band
Old 9th June 2011, 02:51 PM   #18
George,
I have no desire getting a score with this thread. No offense.
I just have first hand knowledge in the topic and I'm glad to lend a helping hand to DIY out there
Cheers!
Originally Posted by gpapag View Post
Hitachi_nut
I just hope you didnít take my intervening as an attempt to argue with you either.
George
Old 9th June 2011, 08:19 PM   #19
gpapag's Avatar
hitachi_nut
It was my pleasure reading your posts here.
George
Oscilloscope as Spectrum Analyzer/Frequency Response AnalyzerHide this!Advertise here!
2x100MHz PC USB Oscilloscope, Spectrum Analyzer, Multimeter, Signal Generator* VIRTINS Vendor's Bazaar 24 2nd August 2011 04:40 PM
Free PC based oscilloscope, spectrum analyzer and function generator sekhar PC Based 3 30th October 2010 06:37 AM
Oscilloscope and Spectrum Analyzer abmoggy Parts 8 4th July 2005 08:08 PM
Copyright ©1999-2017 diyAudio
