Equipment & Tools From test equipment to hand tools
good wire stripper for 26 gauge, which tool?
Old 11th May 2011, 04:44 AM   #1
gychang is offline gychang  United States
Default good wire stripper for 26 gauge, which tool?
is there a good tool to strip small hookup wire?, these things are not solid but stranded also and having lots of problems, Please recommend a tool to help this newbie.
thanks,
gychang
Good sound from Davis, CA
Old 11th May 2011, 04:52 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A Weller Stripi... i can take a picture, they are supposedly hard to find (Allen Wright gifted me mine)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th May 2011, 05:03 AM   #3
frugal-phile(tm)
planet10's Avatar
An eBay auction
Weller stripi - Abisolierer | eBay
dave
Old 11th May 2011, 05:39 AM   #4
scott17 is offline scott17
The T-6 or T-7
TŪ-Stripper Wire Strippers
Old 11th May 2011, 06:32 AM   #5
Stocker is offline Stocker  United States
I've been using Ideal Stripmasters since the wire shop at my last Navy command introduced me to them. They are a bit pricey but an individual hobbyist user should get a couple of lifetimes of use out of them. Random ebay auction to illustrate the type:
Ideal 45-098 Stripmaster Wire Stripper #20 to #30 AWG | eBay
Jesus loves you.
Old 12th May 2011, 02:08 PM   #6
Originally Posted by planet10 View Post
ended in Germany, couldn't locate one in US. Any suggestions?
gychang
Old 12th May 2011, 02:09 PM   #7
Originally Posted by scitizen17 View Post
thanks, will see if local distributor is available, will go after T-7.
gychang
Old 12th May 2011, 02:53 PM   #8
bear is offline bear
expert in tautology
bear's Avatar
The T-7 type tool will work I guess, but it is not very precise... although I suppose someone could be making one with tight tolerances...
The other one, the "Stripmaster" is made by a great many manufacturers over the years and even today, the better ones are very very good and precise. Worth having if you want a quality tool and intend to strip a fair amount of wire.
You can use a sharp razor blade and gently roll the wire or the blade over the wire, not nicking the copper and strip thin wire that way... a little practice scoring the insulation and you can do it very quickly and well.
The best stripper I own is an unknown mfr, but a hand held gun thing with rotary blades. Wish I could buy a few more of them... it is perfect every time and works on teflon wire, which most other strippers have a hard time with... never seen another one like it!
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 12th May 2011, 08:44 PM   #9
_-_-bear
thanks will have to practice. gychang
Old 12th May 2011, 09:25 PM   #10
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
When I get home I will show you the one I settled on after owning many. Not cheap but...
planet10 needs your help:
Let's help Ruth and Dave
good wire stripper for 26 gauge, which tool?Hide this!Advertise here!
why does teflon insulated wires need a very expensive wire stripper? jarthel Parts 7 30th April 2007 03:53 AM
Looking for cheap 26 gauge solid wire in Toronto area 454Casull Everything Else 3 10th April 2007 08:55 PM
Wire gauge calculator? xyrium Multi-Way 7 12th October 2005 11:36 AM
teflon wire stripper sam9 Parts 15 12th February 2005 10:42 AM
fet wire gauge MikeZ Pass Labs 2 21st April 2004 01:43 PM
Copyright ©1999-2017 diyAudio
