Equipment & Tools From test equipment to hand tools
good wire stripper for 26 gauge, which tool?
Old 21st June 2011, 02:37 AM   #31
Conrad Hoffman is offline Conrad Hoffman  United States
The commercial standard seems to be the Ideal strippers. They're accurate and won't nick the strands if used properly. When new, they do well with Teflon insulation, though a thermal stripper is the cats pajamas for that. Though some despise them, sometimes I like the automatic strippers. The best ones don't have blades like the Ideal, but a sort of wide piece of metal where the cutting edge is in the center. They're only for freehand use and don't get into tight spots at all. I'll go out on a limb and suggest that any manual method using knifes and such will leave at least microscopic nicks on the strands that are highly undesirable. You'll fail your wiring and soldering course if any nicks are present!
I've always wanted an automatic stripper for hard enameled wire, but those come a bit dear. They usually have orbiting and spinning abrasive drums.
I may be barking up the wrong tree, but at least I'm barking!
good wire stripper for 26 gauge, which tool?Hide this!Advertise here!
why does teflon insulated wires need a very expensive wire stripper? jarthel Parts 7 30th April 2007 02:53 AM
Looking for cheap 26 gauge solid wire in Toronto area 454Casull Everything Else 3 10th April 2007 07:55 PM
Wire gauge calculator? xyrium Multi-Way 7 12th October 2005 10:36 AM
teflon wire stripper sam9 Parts 15 12th February 2005 09:42 AM
fet wire gauge MikeZ Pass Labs 2 21st April 2004 12:43 PM
Copyright ©1999-2017 diyAudio
