Build -- Active Twin-T notch filter for distortion analysis Build -- Active Twin-T notch filter for distortion analysis - Page 9 - diyAudio
Equipment & Tools From test equipment to hand tools
Old 10th February 2013, 02:33 AM   #81
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Notching out a source's dominant harmonic.
And, for fft use with ADC. Its just a lot more convenient as most of the thing is built already and I have an excess (for parts) 339a. What is needed to add to the osc to make the Q higher for use as a notch filter with the 339a?
Thx-RNMarsh
Old 10th February 2013, 05:16 AM   #82
davada is offline davada  Canada
Thx-RNMarsh
Copy the analyzer's notch filter.
David.
Old 10th February 2013, 05:32 AM   #83
Rick the bridged T in the oscillator is operating as a band pass filter because it's in the negative feedback of the op amp. I don't think it would be an easy undertaking to convert it
to a notch configuration. You'd be better off working with the notch filter in the analyzer section.
David.
Old 10th February 2013, 06:03 AM   #84
RNMarsh's Avatar
Right. Got it.
Thx -- doing 60 things at once over here.
Old 10th February 2013, 06:46 AM   #85
RNMarsh's Avatar
been referring to the 339a as an oscillator... meant analyzer. The notch is on the A3 pcb...Fundemental Rejection Circuit. aka Notch Filter. OK?
Using this portion and/or also modifying the variable passive twin-t to run with the twin-T active circuit are projects for me to think about. Thx-RNMarsh
Old 10th February 2013, 07:17 AM   #86
RNMarsh's Avatar
I was looking at the K-H4400A circuit which uses a bridge-T oscillator which is a notch according to Circuit Description in its manual. That gave me the idea in the first place of using the notch in the spare 339a with the QA400 or other ADC.
But I'm not going to use the K-H4400A for that. I am going to see if it will go lower in THD than the modified 339a because of the trouble getting lowest thd at all frequencies. As you said, you need another wafer to trim thd levels at all freq. The K-H might be better in this respect. I got one a few days ago off eBay for $200. Waiting for it now.
Thx-RNMarsh
Old 10th February 2013, 05:23 PM   #87
Hi Rick,
The mod to the passive twin t would be an easier task. It would be just a matter of lifting the T grounds and inserting the output of the positive feedback amplifier and adding an output buffer.
David.
Old 10th February 2013, 05:25 PM   #88
Thx-RNMarsh
It's been a while since I looked at the 4400A. If they use a Jfet for control element then you will have the same trouble.
David.
Old 10th February 2013, 10:45 PM   #89
richiem is offline richiem  United States
richiem's Avatar
Yep, the 4400 uses a JFET.
Dick Moore
Old 11th February 2013, 12:37 AM   #90
RNMarsh's Avatar
I havent found the limit to be the jFET yet. I started with reaching the limit with an A-Prec model One; then I am now at the low end of the the ShibaSoku. Never changed the jFET... did try but went back to original now. I can get the 339a oscillator to -125-ish. Not sure due to noise there.... need the ADC to look at it now and seperate the noise from the harmonics.
I think the Passive filter I have already (B&K 1607) will be the best approach, also. The box is plenty big to house active circuit AND it is continuously variable over a wide range. Anyone else have such a pasive filter or going to get one asap? :-)
Thx- Richard
Build -- Active Twin-T notch filter for distortion analysisHide this!Advertise here!
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Active Notch Filter design needed Vikash Multi-Way 63 21st May 2007 05:14 PM
Twin-T Lowpass Filter Analysis gmikol Parts 4 17th May 2007 08:16 PM
Noise out of active notch filter reins Multi-Way 0 6th July 2006 07:34 PM
Active notch filter 5th element Solid State 7 6th February 2004 10:06 PM
Copyright ©1999-2017 diyAudio
