Equipment & Tools From test equipment to hand tools
Soldering iron bit rescue
Old 5th May 2011, 10:26 PM   #1
wakibaki is offline wakibaki  United Kingdom
Banned
Default Soldering iron bit rescue
I have this soldering iron from Maplin.
It's supposed to be temperature controlled, but I suspect that it's temperature variable. Whatever, it's not a bad iron, it wasn't too expensive and I was able to buy one off-the-shelf and see what it was like in my hand before I paid the money.
Anyway, I've done a lot of work with it, you can turn it up and down and it will do heavy work like turret boards, and pump out a fair bit of heat when required. It's not the same as a Weller, it's got no magnet in the bit for temperature control, but it's OK.
At the time I bought it, I was careful to check that there were spare bits available, in fact I bought a set of three, the only trouble being that I do a lot of surface mount stuff, and I like a very pointy bit so I had to buy 3 to get 1 I liked.
The other day the expected happened, and the solder finally ate the bit I was using. Of course, the next thing was that I couldn't lay my hands on the spare bits.
Never mind, I nipped off down to Maplin's and bought another set of spares. The only trouble, as it turned out, the thin, pointy bit in this set is not a thin and pointy as the original, and all the ones in the shop are the same. Bummer.
After a couple of days of 'making do' with the best of a bad bunch my creativity re-asserted itself. I have a little lathe I bought off a guy at work when he got a better one and this was an obvious use for it.
I had some brass stock in hand, unfortunately no copper, but I figured the brass would do. Here is the result. 2 hand made bits with one of the bought ones for comparison.
It's important to tin the bit immediately when you heat it for the first time, or you have to abrade it to get it to take solder.
I figure that if I hadn't had the lathe I could still have made these with a couple of files and the workpiece chucked in an electric drill.
w
Old 5th May 2011, 10:29 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I have bought a couple of those irons and wasnt impressed, both died pretty quickly.
I had terrible trouble with the bits not lasting long.
One of the irons had the power supply pack up.
I bought an Antex iron and had trouble free use for over a year now on the same bit.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 6th May 2011, 12:28 PM   #3
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I did the same routine for years; sharpened my copper or brass bits as needed. They would barely last through a soldering session though. The iron coating on real tips makes a big difference in their longevity.
I just recently purchased a GOOT temp controlled iron and after using it for a few weeks now, it's made me wonder why I waited so long to get one. I can get real HAKKO tips for around $1 each, so I don't see the need to ever have to sharpen one again.
Old 6th May 2011, 02:18 PM   #4
phaselag is offline phaselag  United States
The tips are plated to last longer. If the plating layer is compromised, the underlying copper will quickly erode. Any machining, filing or grinding will cut through the plating and the tip will be gone in a short time.
Buy new tips.
paul
Old 6th May 2011, 08:59 PM   #5
Bksabath is offline Bksabath  United Kingdom
Banned
Wakybaki
Got a few of those and they last just a few weeks
Trick is to wait for maplin sales and buy them when price is low 7 / 9
Given up in the end and foud that one of their 60 + irons was on sale at less than half no bad for the money considering branded stuff sels for over 100.
If you need spares send me PM
Got the bad abit to keep al sort of stuff as it may came handy...
Glad to help if I can
Old 6th May 2011, 09:24 PM   #6
simon7000 is offline simon7000  United States
http://www.audioxpress.com/magsdirx/.../simon2894.pdf
This is the article I did on the US version of this "Tool."
Old 6th May 2011, 10:02 PM   #7
Banned
So what do you do with your lathes then? When I fix up the CNC on this one it'll make these for me unattended.
I used lots of different irons professionally, hot air rework stations, some very expensive. Some with RF heating (Metcal I think) took such good care of you, you couldn't get the solder to melt in some circumstances, like if you were trying to rework something built with a higher melting-point solder. I never had one the tip didn't erode through eventually. No soldering iron is perfect, I like one which will deliver some heat when I judge it necessary.
These are hand-worked 1206 and TSSOP24s on a home-made board, done with this iron. I knew a couple of women at Racal I rated as better than me with a soldering iron, but they did it all day, every day.
Now I've got the use back of one that I like when the supplier discontinued the tips I liked. I know why tips are plated, I'm more interested in having something I can fix up myself, although if I could figure a way of plating my own, I'd go for that.
Never mind, I can always melt these down in my flowerpot furnace and recast them.
Or maybe I'll rig up my dremel-alike as a grinder and try cutting some harder stuff.
w
Thanks Bksabath, I've got this one.
Old 6th May 2011, 10:13 PM   #8
I can get similar surface mount results with a <$10 iron and a hand sharpened tip (did it for 6 years). Not having to worry about my tip dissolving half way through a project now is a nice thing though.
One thing I noticed from switching from a dumb-iron to temp controlled iron is that I was used to my tip being HOT!!! I had to set the station to at least 370C to be able to solder the way I was used to.
Old 11th June 2011, 06:08 PM   #9
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Hi, Simon
The Velleman VTSS5V is not a temperature controlled solder station, it just use the usual dimmer triac for variable power. No temperature control feedback action...
Jorge
Old 12th June 2011, 12:31 AM   #10
Originally Posted by Tube_Dude View Post
Hi, Simon
And they stopped advertising it as a temperature controlled iron after the article came out!
Soldering iron bit rescueHide this!Advertise here!
Looking for a soldering iron cent88 Equipment & Tools 9 30th January 2011 09:55 PM
looking for a soldering iron Shpoop Parts 38 8th September 2008 02:58 AM
Soldering iron beerman Chip Amps 27 2nd April 2007 10:12 PM
What soldering Iron? sleepy Everything Else 27 23rd October 2002 10:37 AM
Copyright ©1999-2017 diyAudio
