Use STP brake cleaner on noisy radio? Use STP brake cleaner on noisy radio? - diyAudio
Equipment & Tools From test equipment to hand tools
Old 25th January 2011, 05:22 PM   #1
richardmoon is offline richardmoon  United Kingdom
Default Use STP brake cleaner on noisy radio?
Hi, I have a roberts R25 radio that is very noisy when moving the tuning dial. I remember reading that to clean it I could spray the part with a cleaner. WD40 would work but apparently would then collect dust. As I have some stp brake cleaner, would this work as a contact cleaner or would it destroy the radio?. I also have some head cleaning solution. Would that work?.
Old 25th January 2011, 06:10 PM   #2
Mooly's Avatar
If it's a variable cap with many vanes then it has to be clean but also if/where the centre shaft runs through any bearings then these need to be treated with a little switch cleaner etc... or WD40... but only a pin head sized drop, then move the shaft fully one end to the other and repeat.
I would use a soft brush and vacuum first and then try lubricating the bearings as described... all assuming it's that type of variable cap and not an enclosed one.
Old 25th January 2011, 06:24 PM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
Brake cleaner is nasty s**t. If you choose to use it, I'd definitely take the variable cap out of the radio first. Make sure there aren't any plastic parts on the cap before blasting it.
I'd be gentle. As Mooly suggests - maybe all you need is a tiny drop of acid free oil in the right place. Use a syringe and hypodermic needle.
~Tom
Old 25th January 2011, 08:35 PM   #4
Thanks for the answers. I think i knew brake cleaners was too vicious, but i've got six cans of it to use up!. I'll leave it in the garage where it belongs.
I'll try the gentle approach as above. Thanks again.
Old 26th January 2011, 04:34 PM   #5
barrymagrec is offline barrymagrec
Back in the 1950`s my dad use to fix noisy volume controls with a small drop of "Redex" (upper cylinder lubricant) but when he got some more 30 years later they had changed the formulation and it no longer worked.
Barry
Old 26th January 2011, 05:34 PM   #6
DF96 is offline DF96  England
Why not buy some switch cleaner? This is made for the purpose: cleaning switches and pots.
Old 26th January 2011, 05:39 PM   #7
Well yes, but back in the fifties switch cleaner was novel and expensive whereas a shot of Redex was next to nothing from any garage.
Old 26th January 2011, 05:42 PM   #8
LT99 is offline LT99  United States
Be careful with brake cleaner if it's near a soldering iron or other heat source. I've seen several warnings about brake cleaner nearly killing people after using it to clean metal parts and then welding them. It forms a poison gas from the heat. I don't know if a soldering iron is hot enough to make this happen but look into this matter before using brake cleaner. Better safe than sorry! Brake Cleaner = Phosgene Article
Use STP brake cleaner on noisy radio?Hide this!Advertise here!
DIY Power Brake? eeka chu Instruments and Amps 30 17th January 2015 06:05 PM
SP10 MkII Brake jlsem Analogue Source 4 19th July 2008 07:32 PM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 04:07 PM
Twinax, UTP, or STP for LVDS interconnect? jwb Digital Source 7 27th December 2004 07:52 AM
Cat 6 STP as subwoofer line level cable creek Everything Else 6 24th October 2004 07:50 PM
Copyright ©1999-2017 diyAudio
