Equipment & Tools From test equipment to hand tools
Is a 60w solder iron strong enough for electronic soldering?
Old 12th August 2010, 05:56 PM   #1
rg12 is offline rg12
Default Is a 60w solder iron strong enough for electronic soldering?
I need to solder and desolder some resistors and capacitors.
I have a new 60w basic solder iron, is it ok for that use? my previous
one was 30w.
Old 12th August 2010, 06:17 PM   #2
timpert is offline timpert  Netherlands
A 60W soldering iron might be a tad too much if it is not temperature regulated. For basic PCB soldering, something around 25W is more appropriate. Higher powered irons are often seen used in electronics, but most of the time these are temperature regulated. Otherwise, you'll quickly fry your board and the components on it.
Old 14th August 2010, 01:00 PM   #3
indianajo is offline indianajo  United States
indianajo's Avatar
Yeah, if you bought the 60w because the 30w was too slow, buy a chisel tip for the 30w iron. Chisel tip is a cylinder right out to the very end, which is flat and about 3 mm wide and .5 mm thick. If your 30w iron is not supported by different tips, buy a Weller WP25. Get the tip on the same freight order, it comes with a useless pointy tip, too.
If you bought the 60 because the silver solder won't melt-join the club, it doesn't work very well. I use 65/35 tin lead, which is practally banned in Europe because of all the lead shielded KCRT's businesses dumped in the landfills. Update your profile, your location matters on what advice you get. If you live in Europe you need a very expensive iron, although wave soldering by professionals works better. (and is why big companies are in favor of the lead solder ban, repairmen can't afford wave soldering).
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 14th August 2010, 02:03 PM   #4
Andrew Eckhardt is offline Andrew Eckhardt  United States
An unregulated 60 watt iron is good for for very high speed work, especially on large connections.
Even a 45 watt iron can be too hot for PC board work, but with a little care it makes clean connections quickly.
30 is actually quite useful and relatively maintenance free if good enough quality. Avoid anything with a set screw for the tip.
Old 14th August 2010, 02:06 PM   #5
aptquark is offline aptquark  United States
aptquark's Avatar
I would go for a smaller wattage gun in your case....for me...I use a 2000 watt. I just want the gun to LOOK at the joint and solder it. Less issues that way.
Old 16th August 2010, 06:07 PM   #6
star882 is offline star882  United States
star882's Avatar
I use a 60W Hakko with a light dimmer to adjust the power. Full power for large connections, throttle back for PCB work.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 17th August 2010, 05:05 PM   #7
DF96 is offline DF96  England
I have always used 15W on PCB, and 25W for point-to-point. Normal leaded solder - Ersin Multicore is about the best 'normal' brand in the UK.
Old 17th August 2010, 07:18 PM   #8
pjp is offline pjp  India
pjp's Avatar
Wouldn't using a dimmer change the temperature of the iron ? (instead of the wattage)
I would have thought that wattage = mass of copper in the bit.
A high wattage iron shouldn't run any hotter, its just able to heat up larger objects.
OP: 30W is more than necessary. If your solder joints are coming out bad, you've got some other problem.
Old 18th August 2010, 01:55 AM   #9
I just wanted to replace my simple old 30w, so i bought a new 30w
and another 60w for non pcb work.
Thanks guys.
Old 21st August 2010, 12:46 AM   #10
davada is offline davada  Canada
If it's an unregulated 60w iron you can use a variac for temp control, if you have one.
David.
Is a 60w solder iron strong enough for electronic soldering?Hide this!Advertise here!
looking for a soldering iron Shpoop Parts 38 8th September 2008 02:58 AM
Soldering iron beerman Chip Amps 27 2nd April 2007 10:12 PM
soldering iron temp and solder wire melting point. jarthel Parts 6 10th October 2006 03:12 PM
Strong solder, how does it sound? classd4sure The Lounge 33 23rd September 2006 09:47 AM
What soldering Iron? sleepy Everything Else 27 23rd October 2002 10:37 AM
