Equipment & Tools From test equipment to hand tools
Transformer Bobbin Turns Counter
Old 27th July 2010, 05:01 PM   #1
speakerman is offline speakerman
Default Transformer Bobbin Turns Counter
Does anybody have any suggestions for buying a commercial Turns Counter (to 5 digits) or how to build one myself? Thanks for your responses.
Old 27th July 2010, 08:32 PM   #2
bob91343 is offline bob91343  United States
How permanent a unit do you want? Or is it for one use?
You can buy turns counting dials. Try MFJ in Mississippi for starters.
You can set up a rotating magnet/coil assembly with an electronic counter.
Old 27th July 2010, 09:31 PM   #3
jlsem is offline jlsem  United States
jlsem's Avatar
The easiest and cheapest way is to rig a mechanical plunger that keys the = button of a cheap calculator after you've entered 1+1. I personally use a Veeder-Root mechanical counter actuated by a cam on the rotating shaft. For extra fanciness I added a small ball bearing to the lever on the counter.
http://cgi.ebay.com/SALE-VEEDER-ROOT...#ht_500wt_1154
John
Old 27th July 2010, 11:09 PM   #4
Steerpike is offline Steerpike
Steerpike's Avatar
I use an ICM7217 chip & 7-seg display to wind transformers on my lathe. It took a bit of soldering to put it all together on strip board.
The trigger can be a reed switch actuated by a tiny magnet on the chuck.
The caclulator trick is much quicker! You could again solder a reed switch across the necessary keypad contacts.
Steerpike's Toybox
Old 31st July 2010, 09:43 PM   #5
mickeymoose is offline mickeymoose  Canada
Speakerman: Please do not double-post! E
Old 1st August 2010, 03:36 AM   #6
Default Reply to postings
Sorry, Mickeymoose/E. I am relatively new to blogging and did not mean to do inappropritate entries. I wanted to reach as many people as possible in different categories; I assume that is what you mean by "double-posting". Will not do so again. Thank you for the heads-up.
Thank you to those who have responded with advise, it is greatly appreciated. I will check your suggestions out.
Old 13th August 2010, 04:50 AM   #7
Hi, Guys -
Found a great site by Gerry Walterscheid Jr., check it out:
The Engineer's Notebook: Universal Coil Winder
I am going to attempt a motorized version.
Transformer Bobbin Turns CounterHide this!Advertise here!
Transformer Bobbin Turns Counter speakerman Parts 3 31st August 2010 08:12 AM
output transformer turns per volt ataul Tubes / Valves 14 8th May 2010 09:59 AM
McIntosh transformer turns ratio SpreadSpectrum Tubes / Valves 8 27th December 2008 10:50 PM
electrostatic transformer turns ratio willyhoho Parts 1 1st April 2006 05:46 AM
SMPS Transformer Turns Equations Help venki Power Supplies 4 16th February 2006 02:02 AM
Copyright ©1999-2017 diyAudio
