Equipment & Tools From test equipment to hand tools
Need Help on ac/dc converter@!!!!
Old 12th June 2010, 04:37 AM   #1
msj965 is offline msj965  United States
Default Need Help on ac/dc converter@!!!!
Hello Masters
I have a problem regarding my ac/dc converter 12vdc/5a output.Recently I measure the output voltage with the use of a multimeter.I got the actual measurement of 14.5v,which is above normal than the specs.is there any way that I can put it back to 12v? I check the internal parts no burn @ all.inside there is IRF820and smps10 rctifier.next time I'll post the converter..
Old 14th June 2010, 07:46 AM   #2
gmphadte is offline gmphadte  India
It is a nonregulated converter. It is correct and the voltage will drop on load. However, do not use it for sensitive, high quality load
Gajanan Phadte
Old 14th June 2010, 08:24 PM   #3
firechief is offline firechief  United States
firechief's Avatar
hi msj965 , Ill bet this is a "wall wart". Black plastic thing that plugs right into the wall with a cord on it. If so, that is normal. Post the information written on it if you are still curious. What is it used for?
Need Help on ac/dc converter@!!!!Hide this!Advertise here!
we can offer power module of DC/DC Converter & AC/DC Adapter auling Vendor's Bazaar 0 12th May 2009 04:48 AM
DC-AC converter circuit ThSpeakerDude88 Car Audio 33 13th September 2008 05:46 PM
12 DC to 220v AC converter redhorseaudio Power Supplies 1 5th November 2005 05:53 PM
AC to DC converter with selectable voltages? Audiophilenoob Power Supplies 28 11th October 2005 05:51 PM
AC to DC converter with selectable voltages? Audiophilenoob Multi-Way 0 9th October 2005 02:33 AM
Copyright ©1999-2017 diyAudio
