Equipment & Tools From test equipment to hand tools
DIY Analog-to-Digital Converter project.Audio measurements tool
Old 29th March 2010, 03:00 PM   #41
jackinnj is offline jackinnj  United States
jackinnj's Avatar
The output of the Super Oscillator is a bit high for the HP3577, so an attenuator is necessary. The display is that of the bleed through from the DA4084 notch filter.
Perhaps you've seen this chart -- comparing the AP Generator with a KH-4400:
Old 29th March 2010, 06:22 PM   #42
Frex is offline Frex  France
Arrow oscillator.
Hello,
jackinnj, below how looks my version of the LT oscillator.
Ghg, i'm not sure that active notch filter allow to improve measurement resolution of THD.
I have built one, using two AD797, and finally, it seem to add THD...
Fully passive notch filter is also poor, impedance is too high and it's low Q factor give high attenuation at harmonics frequency.
Left, the new AA5381 ADC working, at right the oscillator and it's differential outputs.
Inside the oscillator...
Left, my previous ADC (with AKM5394).At center the new AA5381 and at
right the oscillator again.
Frex.
Old 29th March 2010, 07:13 PM   #43
jackinnj's Avatar
Very nice work. I tried an aluminum enclosure for my Super-Oscillator, but it would pick up the 60Hz! That's why it's in a steel container. I had to tweak the cap values to get it spot-on for 10kHz.
Old 29th March 2010, 07:57 PM   #44
Arrow results.
Hello,
Thank jackinnj, yours is also nice !
I have noticed that the DC source of the oscillator must be quiet for very low HD. Bad line rejection issue could add intermodulation around Fosc.
To solve it, very good PSU or battery powering is required.
Using metal housing is not a problem if is it connected to ground (of oscillator).Metal case improve line and EMI rejection.
I use for mine with a JSR06 low noise PSU.
Now, all my measurements results on the AA5381 ADC, and some others with my older ADC to compare.
Hello,
Old 30th March 2010, 09:43 AM   #45
ghg is offline ghg  Austria
ghg's Avatar
You both did a fine job on these 10kHz super oscillators, I am jealous ...
Any boards left, you layout kings ???
>frex: Ghg, i'm not sure that active notch filter allow to improve measurement
>resolution of THD.I have built one, using two AD797, and finally, it seem to add THD...
Well, the AD797 is a beast, I never managed to get it 100% stable on the breadboard and was too lazy for doing a good pcb layout,
but just take an AD712 and all is fine. Take a look at the plot below, a standard active twin T dual opamp twin T, gives 60dB attenuation,
THD is at the same level as the related "sweet spot" FFT of the TI eval board.
A standard soundcard without this notch would be worse by 20dB.
>Fully passive notch filter is also poor, impedance is too high and it's low Q factor >give high attenuation at harmonics frequency.
Works too, use just a +20dB FET buffer and take the insertion loss in account.
I hate "sounding amps", except these are Marshalls, driven by Eric C. or Jeff B., period.
Old 30th March 2010, 11:43 AM   #46
iko is offline iko  Canada
iko's Avatar
Gary, do you mean a fet input opamp based +20dB buffer after the notch filter? The buffer/amp would also have to be very low thd+n, no? I'm planning to build a notch filter myself so I'm interested in what you built.
Old 30th March 2010, 12:30 PM   #47
jackinnj's Avatar
One of the guys at big semi bought all the boards I had made -- I don't know if they ever got them working!
Same thing happened when I built the phase-meter from an Intersil Application Note -- the semi companies will sell their development modules for a fraction of the engineering time and money which goes into them in the hopes of selling tens of thousands of parts.
AD797 seems to like a copper plane underneath it -- if you don't want to lay out a PCB consider "dead bug" style development. Development boards are OK, but really fall down in low noise circuits as they pick up all kinds of radiated energy. With the AD797, it's important as well to read the entire datasheet!
Old 30th March 2010, 03:39 PM   #48
ghg,
The PCB of my oscillator is not professional. It's home made.
If you are interested, i can send you Gerber files to build it.
(you can read/print it with any Gerber reader like GCprevue or others).
(Maybe if enough DIYers are also interested, it could be a good idea to get professional PCB from PCBcart or others ? )
For the notch filter, i will try to work on it this week with others OPAMPs.
Like says ikoflexer , could you post or send your schematic of notch filter ?
Frex
Old 30th March 2010, 04:13 PM   #49
iko's Avatar
Before seeing this discussion I was thinking of building the attached. Not exactly with that opamp... but something like that. Haven't thought about the 20dB buffer/amp yet.
Old 30th March 2010, 09:57 PM   #50
ghg's Avatar
TWIN T notch filter
1. passive + 20dB amp:
EDN -- 11.10.94 Oscillator keeps THD below 1 ppm Fig. 2
2. active:
Distortion Analyser Fig. 4
@frex: Gerber would be fine, thanks a lot.
@ikoflexer:
>Gary, do you mean a fet input opamp based +20dB buffer after the notchfilter? The buffer/amp would also have to be very low thd+n, no?
Imagine 0dBV to the notch, after the notch you will get app. -60dBV.
Todays opamps show about/or less than -100db THD ( 0dBV input,1kHz,+20dB gain ).
At an input of -60dBV we have app. -160dB opamp selfdistortion.
DIY Analog-to-Digital Converter project.Audio measurements toolHide this!Advertise here!
need an analog-to-digital converter schematic prorms Digital Source 0 28th March 2008 08:29 PM
Digital to Analog Converter DAC With Cable mg16 Swap Meet 1 11th September 2006 06:27 AM
Analog to Digital converter amirmk Digital Source 9 26th November 2005 12:50 PM
Differences between Digital and Analog Audio oscarcasalini Digital Source 1 7th January 2004 11:32 PM
Digital to Analog converter condor655 Digital Source 4 15th May 2003 10:02 PM
Copyright ©1999-2017 diyAudio
