Equipment & Tools From test equipment to hand tools
DIY Analog-to-Digital Converter project.Audio measurements tool
Old 7th February 2010, 08:04 AM   #11
Frex is offline Frex  France
Hello everyone,
I think now soon send Gerber files for pcb manufacturing.
I think use "pcbcart" service. It' offer cost effective solution and they job is very good.(145 for 2 boards including shipping).
I hope that my job doesn't yet contain many errors.
Frex
Old 9th February 2010, 09:03 PM   #12
noisewarrior is offline noisewarrior  United States
ghg,
Thanks for the good tip, but that -168dB floor in your plot, is relative to what voltage?
Originally Posted by ghg View Post
Hi Frex
Impressive pcb work, fine.
Maybe you are looking for something readymade, and possible unbeatable, take a look at TI's PCM4222EVM ( US $ 149,-- +shipping ).
You just need a dual 15V and single 5V powersupply.
Here a FFT; source Krohn-Hite 4400A, both units SLA battery driven, PC interface RME-PAD via AES/EBU.
Old 10th February 2010, 04:35 AM   #13
Ghg, I would also like to know the full setup of of your measurements.
A fully detailed explanation will be welcome
Frex
Old 10th February 2010, 12:47 PM   #14
ghg is offline ghg  Austria
ghg's Avatar
Analog oscillator:
KROHN-HITE 4400A ( SLA battery driven ) unbalanced, 50 Ohm output
ADC:
PCM4222EVM ( SLA Battery driven ) AES/EBU-output
PC interface:
RME-Digi96/8-PAD AES/EBU input
FFT software:
Spectraplus 5.0 demo (download at SpectraPLUS - Audio Spectrum Analyzer)
fs=44.1kHz, 1048576 points, Blackman, 24 bit.
What additional info do you need ?
Gary
I hate "sounding amps", except these are Marshalls, driven by Eric C. or Jeff B., period.
Old 10th February 2010, 04:04 PM   #15
ghg,
What is the rms level of the analyzed signal ?
The spectrum analyzer is it calibrated in real dBv ?
It will be interesting to make measurements with higher sampling rate,
because noise increase.
Do you use weighting filter ?
Can you post more pictures ?
Frex
Old 23rd February 2010, 04:06 PM   #16
I have ordered 2 PCB at pcbcart.
I wait them in about 18 days.
of course, i will post a picture as soon it arrived.
Frex
Old 3rd March 2010, 01:47 AM   #17
grenert is offline grenert  United States
One concern I have with using ADC designs for testing is that it is too easy to blow up the front end with too much voltage. What do you think about adding a voltage divider and/or diode clamps before the first opamp stage? The DIY oscilloscope mentioned elsewhere here and detailed at:
DPScope - A Low-Cost PC-Based Oscilloscope
uses both.
Old 3rd March 2010, 03:38 PM   #18
Hello grenert,
I essentially test audio devices. In my many tests, with my first ADC design using AKM5394, i have never damaged the input stage.
Of course, if you test an audio amplifier outputs, the voltage can be higher than tens volts, and you need to add a divider to fit to the input scale of the ADC.
But i agree, about the need to protect inputs if the device is intended for high voltage measurements.
If your are interested by the ADC, you can easily add your own attenuator (maybe internal..).
The adding resistors ladder network for the input attenuator and a protection diodes at OPAMP inputs, it degrade noise performance and can cause non-linearity and distortion (leakage current).
Frex.
(For the next version of the pcb design, i will add protection diodes which could be solder only if necessary) :-)
Old 6th March 2010, 12:24 AM   #19
iko is offline iko  Canada
iko's Avatar
Nice project Frex, found this just as I was thinking about the same thing. Any updates?
Old 6th March 2010, 06:24 AM   #20
As i have already wrote, the PCB was sent to manufacturer, and i wait it for the next week. I will post pictures of the PCB as soon i will receive it.
I must be patient now...
Fortunately, i can work on others audio projects pending.
Frex.
final schematics :AA5381v1sch
DIY Analog-to-Digital Converter project.Audio measurements toolHide this!Advertise here!
need an analog-to-digital converter schematic prorms Digital Source 0 28th March 2008 08:29 PM
Digital to Analog Converter DAC With Cable mg16 Swap Meet 1 11th September 2006 06:27 AM
Analog to Digital converter amirmk Digital Source 9 26th November 2005 12:50 PM
Differences between Digital and Analog Audio oscarcasalini Digital Source 1 7th January 2004 11:32 PM
Digital to Analog converter condor655 Digital Source 4 15th May 2003 10:02 PM
