Equipment & Tools From test equipment to hand tools
DIY Analog-to-Digital Converter project.Audio measurements tool
Old 25th April 2011, 04:47 PM   #161
klewis is offline klewis  United States
klewis's Avatar
Originally Posted by jackinnj View Post
Here's mine:
Jack,
I'm thinking of making one myself. Did you use the +-7.5 volts to run the opamps as well? The ap note isn't clear on this point.
Ken
Old 25th April 2011, 06:33 PM   #162
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
One more thing, I know Frex is busy but perhaps this will help others. The Tent clock doesn't really fit very well. You need to move the 10uF capacitor off-center of its pads, and tilt the clock to avoid an inductor and capacitor. See pictures.
Regardless, the clock will make contact with the metal casing of the input transformer. I'm hoping this is okay, as there is no other way around it that i can see. Anyone know for sure if this is okay?
Old 26th April 2011, 12:39 AM   #163
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by klewis View Post
Jack,
Ken
I used "D" cells, a pack of 5 on each side.
In my case, it was very important to shield the oscillator, so both batteries and the PCB were housed in a big Danish cookie tin.
Old 26th April 2011, 02:07 AM   #164
klewis's Avatar
Thanks Jack. I get the strong sense that you love Danish cookies .
Old 1st May 2011, 09:24 AM   #165
EUVL is offline EUVL  Europe
Just finished my oscillator.
Battery powered, Lemo2B for balanced output. Rest is standard.
At the moment -130dB H2 limited by noise floor of spectrum analyser.
Shall measure again in 2 weeks when I have access to an AP.
Thanks for the PCB work,
Patrick
Old 1st May 2011, 03:52 PM   #166
luvdunhill's Avatar
Patrick, looks good! Do you anticipate any problems due to the two halves of the battery pack not discharging at equal rates? Or is the on board regulator enough to deal with this?
Old 1st May 2011, 04:44 PM   #167
a) The oscillator has pure AC output. My test with lab supply suggested that consumption was equal for positive and negative rail.
b) 20 AAA alkaline batteries cost 3 Euros and will last me for hours. So even if they are discharged unevenly, just replace new.
c) I don't think I'll be switching them on very often.
Too many advantages with batteries IMHO.
Patrick
Old 8th August 2011, 02:42 AM   #168
PB2 is offline PB2  United States
PB2's Avatar
Originally Posted by ghg View Post
Hi Frex
Impressive pcb work, fine.
Maybe you are looking for something readymade, and possible unbeatable, take a look at TI's PCM4222EVM ( US $ 149,-- +shipping ).
You just need a dual 15V and single 5V powersupply.
Here a FFT; source Krohn-Hite 4400A, both units SLA battery driven, PC interface RME-PAD via AES/EBU.
Does your KH4400A have any mods since most people quote .0001 - .0003% distortion for that unit?
Old 8th August 2011, 03:18 PM   #169
ghg is offline ghg  Austria
ghg's Avatar
Well, let's remember:
1. SLA driven, to get rid of 50Hz artefacts and cross IM.
2. Calibration of the AGC fet section according to the service manual,
available at Jan Dupont's great site.
3. Replacement of the output level pot, got a 10 turn Bourns there.
Getting the 4th zero in THD was the "sweet spot" in connecting the KH4400A to the TI ADC eval board. So, even a slight change of the volume level increases THD to 0.000x. At least this is THD, not THD+N; did 10^6 FFT points to minimize the noise part.
BR
Gary G.
I hate "sounding amps", except these are Marshalls, driven by Eric C. or Jeff B., period.
Old 8th August 2011, 04:12 PM   #170
PB2's Avatar
I see, makes sense, thanks.
DIY Analog-to-Digital Converter project.Audio measurements toolHide this!Advertise here!
need an analog-to-digital converter schematic prorms Digital Source 0 28th March 2008 09:29 PM
Digital to Analog Converter DAC With Cable mg16 Swap Meet 1 11th September 2006 07:27 AM
Analog to Digital converter amirmk Digital Source 9 26th November 2005 01:50 PM
Differences between Digital and Analog Audio oscarcasalini Digital Source 1 8th January 2004 12:32 AM
Digital to Analog converter condor655 Digital Source 4 15th May 2003 11:02 PM
