Equipment & Tools From test equipment to hand tools
Radio Shack 33-2050 Sound Level Meter - Service
Old 29th December 2009, 11:33 PM   #1
MartinQ is offline MartinQ  Canada
Default Radio Shack 33-2050 Sound Level Meter - Service
I have a Radio Shack (Realistic) 33-2050 sound level meter that is on the blink and it looks like something is wrong with the analog meter itself. The schematic on Eric's site is a bit hard to read (http://mysite.verizon.net/tammie_eri...50/rs_spla.gif), but it looks like the meter is rated for 135 uA and 2k ohm. This one measures in the megaohms and putting a 9V battery across it (9.22V) only provides about 15% movement on the needle.
The only markings on the meter are TEC M-700B. The card inside is printed 700B-91 (assuming that means 1991).
Any suggestions (except 'get a new one') would be great. I would hate to put down a good piece of gear especially after it's been cleaned and all the contacts coated with DeoxIT. I was just getting ready to swap out the capacitors as described here:
RS SPL METER (33-2050) MODIFICATIONS
Old 30th December 2009, 12:11 AM   #2
I found a slightly more readable schematic that was uploaded by Salas in an old thread.
SPL meter corrections?
So, it looks like the 2k ohm meter is in a voltage divider with R19 (82k) for the battery check circuit. That means I should be getting full-scale deflection with less than 300 mV.
Old 30th December 2009, 02:09 AM   #3
Conrad Hoffman is offline Conrad Hoffman  United States
Well, if the meter was good before, putting a battery across it is guaranteed to burn it out instantly. My guess is it will be near impossible to find a new meter for the thing. The only distant hope is that the meter developed a bad connection somewhere that you might be able to find and fix. It's a very distant hope. Use a magnifier and inspect any wires and coils you can see for breaks or oxidation. One *never* checks a uA or even a mA meter without putting a large resistor in series with it.
CH
I may be barking up the wrong tree, but at least I'm barking!
Old 30th December 2009, 02:42 AM   #4
Hi Conrad, yes I understand the meter should blow by having 9V put across it. I was trying to find out why I could not get any significant deflection on the meter, even for the battery check (2k/82k voltage divider with a 3k load across the battery). Like I said, the meter measures in the megaohm range so putting 9V across it has little effect.
I'll try to post some pics, but so far everything tests out as I stated. I can get the meter probes right down to where the tabs connect with the coil, but it's still reading 1-3 megs. I can't see the wire connections with the bare eye, so I'll see if I can get some macro photos to post.
Old 30th December 2009, 05:53 AM   #5
A few pictures of the TEC M-700B meter.
Old 30th December 2009, 01:59 PM   #6
Nice photos & you have as good access to the coil as you're going to get. About all I can suggest is reheating the joints where the wire attaches, otherwise the open must be in the coil somewhere. Try to get it under a low power stereo microscope- when working with hi-fi always try to use a *stereo* microscope. If that doesn't work, I'd look for a meter movement from whatever you can find, and try to adapt it to the case. If it's the same sensitivity or more, you can just scale it with a resistor. If less, more fiddling is involved. Probably sacrilege, but you could also make an adapter plate and put in one of the little inexpensive digital meters various places sell.
CH
Old 31st December 2009, 08:49 PM   #7
I pulled the coil out to have a better look at things. Even with it out, it's impossible to see the coil connections with the naked eye so I did some snooping with a cheap USB microcam. I managed to get some up-close visuals on both ends of the coil, but I can't detect any problems or see the actual connection. I think a proper microscope would definitely help.
Radio Shack 33-2050 Sound Level Meter - ServiceHide this!Advertise here!
Radio Shack SPL Meter - Anything Better? BlueWizard Multi-Way 20 13th March 2009 04:30 AM
Radio Shack SPL Meter and justMLS - I'm getting odd measurements... fjhuerta Multi-Way 19 2nd January 2008 03:39 AM
FS: Radio Shack Analog Sound Level Meter Javachip Swap Meet 2 23rd October 2007 03:58 PM
SPL sound meter smaller than Radio Shack Daveis Equipment & Tools 4 21st June 2007 09:27 AM
Radio Shack SPL meter with DCX2496? mazeroth Digital Line Level 15 17th May 2005 05:10 PM
