Equipment & Tools From test equipment to hand tools
Pantograph drawing: need help pls
Old 15th December 2009, 04:42 PM   #1
Steerpike is offline Steerpike
Steerpike's Avatar
Default Pantograph drawing: need help pls
Does anyone know anything about pantographs?
I made a rudimentary 'test' setup from strips of plastic an wood, before I go all out on making a metal one, but my prototype doesn't work!
I want a scaling factor of around 10:1, i.e., the drawing must be 10% of the stencil size, so that any errors tracing the stencil are almost invisible on the drawing. I made (A+B)=50cm (about 15 inches).
I figured the scaling factor would be
A/(A+B) = C/(C+D)
and to maintain a 'square' aspect ratio A=C and B=D.
(my diagram is a little distorted, but tha actual machine is accurately measured)
But I'm getting some very trippy drawings that look like Salvadore Dali's. So my trigonometry is wrong!
Does anyone know the correct trigonometry for this thing and what I did wrong?
Here's a neat online illutration of operation, but they don't give any info on how to calculate the arm lengths:
*** pantograph Java applet***
Steerpike's Toybox
Old 15th December 2009, 09:07 PM   #2
Steerpike's Avatar
I've figured out WHY I'm getting distorted drawings - it's because the pen is slightly offset from the fulcrum.
But I still need assistance to figure out a way to compensate for this. It's physically impossible to place the pen right at the fulcrum - unless it involves a very elabrate bearing with a hole in the centre.
Steerpike's Toybox
Old 15th December 2009, 09:16 PM   #3
neutron7 is offline neutron7  Canada
neutron7's Avatar
just make an ofset for the stylus which is 10 times (or whatever your scaling is) as much as the pen is offset and in the same direction., in your case D would have 10x the distance between the pen and its closest pivot added to it.
Old 15th December 2009, 09:28 PM   #4
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Looks to me like dim "C" should be equal to dim "B", forming a square in other words.
Also, moving the pen to here will help:
Old 15th December 2009, 09:43 PM   #5
Steerpike's Avatar
That's what I thought at first; but it doesn't work. Hard to explain what happens in words... the offset required changes as the arm angles change. A fixed offset on the stylus doesn't correct for that.
BUT, I have found an alternative design, that I will try tomorrow. How to set the scaling of this arrangement is also a mystery for now - I'll have to revise some geometry!
Steerpike's Toybox
Pantograph drawing: need help plsHide this!Advertise here!
PCB Drawing for STK4231V ? thoronx Chip Amps 1 26th June 2008 09:04 PM
drawing freeware??? aardvarkash10 Full Range 12 15th May 2008 01:33 PM
My first GC PCB drawing... flying Chip Amps 8 14th January 2005 07:24 AM
CAD Drawing Doug Everything Else 8 8th October 2003 03:52 PM
Ariel 6 drawing kid Multi-Way 8 1st May 2002 03:30 PM
