I have a Peak Atlas ESR meter, small and works
Peak electronics
Check CPC / Farnell / Rapid for pricing as you can find discounts sometimes.
Peak electronics
This guy wrote the book
ESR meter page
His inexpensive little instrument opened up a whole new income stream for me (repairing switchmode PSUs)
M
ESR meter page
M
I know this is not what you're wanting. But it might be helpful, in a pinch:
TESTING ESR OF ELECTROLYTIC CAPACITORS, without an ESR meter
- Tom
- Tom
I agree, an LCR meter is essential for the DIY audio hobbyist. An ESR meter, however, is also essential if you do much repair. A decent ESR meter will let you spot bad parts in-situ, whereas an LCR meter is near to worthless for that. Not having an ESR meter, I usually pull parts or do the manual method linked above.
CH
CH
Hello all--newcomer here,
I just purchased a Peak ESR70 a couple weeks ago, in deference to the "blue" kit, and found this thread while searching for more info. It works quite nicely however I found the leads to be absurdly short and the supplied crocodile (alligator here in Florida) clips to be worthless for in-circuit testing.
The lead length was an easy fix, I cut the twin coax line off of a cheap set of "ear-buds" and used both the shield and center of each cable for each pole of the tester's input.
To address the in-circuit issue I made up a set of tweezers from Popsicle sticks--nothing magical in the construction, just cut the pieces/parts to fit and glue 'em up--I built up each leaf (tweeze?) with stacked pieces to provide a grip and then applied the heat-shrink tubing.
The probe tips are 1" brass escutcheon pins bent up as needed and epoxied in place--I have since bent the probe tips inward so as to grab solder pads more forcefully. In use I clip the croc's to the exposed head of the pins.
It all works well and will calibrate to 0.00Ω with no problems...
URL's only available now by webarchiveThis guy wrote the book
ESR meter page
M
ESR meter page
but also by new website
ESR meter page
more URL's:
Capacitor Lab - Bob Parker ESR Low Ohms Meter from EVB Portugal
EVB ESR METER PAGE
https://anatekinstruments.com/products/fully-assembled-anatek-blue-esr-meter-besr
A schematic for ESR meter from Italy you will find in post #1942 under
https://www.diyaudio.com/forums/parts/151392-electrolytic-capacitors-195.html#post6746282
additional advices are here
https://www.diyaudio.com/forums/equ...-advice-capacitor-esr-tester.html#post6746294
- Design & Build
- Equipment & Tools
- ESR Meter
