Equipment & Tools From test equipment to hand tools
Temperature setting for soldering?
Old 4th December 2009, 09:19 AM   #21
R.I.P.
eutectic solders are virtually a must for electronics work.
63/37 is the cheapest and easiest to use. melts @ 361degF
That 62/36/2ag is very good but quite a bit more expensive. and melts @ 354degF
Don't use lead free for home use. Leave that to the factories that are forced into using it.
regards Andrew T.
Old 4th December 2009, 09:49 AM   #22
thermal runaway is offline thermal runaway  United Kingdom
thermal runaway's Avatar
Little tip when soldering RCA plugs , if u have one , push the plug into a socket before soldering , holds everything in place if they are inclined to soften a bit.
Old 4th December 2009, 10:15 AM   #23
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Proper solder for electronics is not lead free and not silver. I use Autosol RA 2% flux 0.7mm from Warton Metals Solders, Cored Solder Wire, Solderpastes, Fluxes, Rosin Free Solders and Lead-Free Solders you can buy in small quantity or a reel.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 4th December 2009, 10:52 AM   #24
I've always used Savbit by Multicore Solders Ltd.
Old 5th December 2009, 09:41 AM   #25
uplees8 is offline uplees8  United Kingdom
Thanks for the information, I will look into it. I think it was threads on the net that led me toward silver solder in the first place... You can read and read, but in the end you just have to have a go and find out the hard way I guess.
Old 5th December 2009, 11:04 AM   #26
R.I.P.
there is nothing wrong with including silver in the solder.
Even better is including copper like the savbit, but whether it's copper and/or silver try to find a true eutectic.
regards Andrew T.
Old 10th December 2009, 01:43 PM   #27
Doomlord_uk is offline Doomlord_uk  United Kingdom
Inside the EU, that's all you can get (legally). It's a PITA to work with. I have to get another solder station because the one I got initially doesn't get hot enough.
Bonus question for the thread - is it a bad idea to mix lead and lead-free solders? IE using lead-free to service a leaded solder board?
Old 10th December 2009, 01:54 PM   #28
R.I.P.
leaded solder is not illegal, nor is it illegal to sell it and finally it is not illegal to use it.
If you need to declare your product Rohs compliant then there are rules to follow. If you don't need to be Rohs compliant then those rules do not apply.
I believe one of our solder experts (John?) said it is a very bad practice to mix solders.
regards Andrew T.
Old 10th December 2009, 01:58 PM   #29
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
doomlord, leaded solder is legally available inside EU. It's just not allowed to be used in certain commercial products, like white ware, consumer electronic stuff etc.
yes bad idea...use leaded solder,it is explicitly allowed in repairing old pre-rohs stuff.
regards
Old 10th December 2009, 10:30 PM   #30
Default Amazed at how complicated solder can get...
I have spent hours finding out what I can about solder. I thought it was the silver or non-silver lead free stuff from Maplins, how wrong can you be?
I found out that lead free is only compulsory (presumably to commercial repairs) in repairs to products post 2006 sometime, and new commercial production (sorry for the vagueness). Us DIYers are free to use tin/lead/fluffy dog in any proportion you can find and care to play with. I found an interesting article:
http://www.dklmetals.co.uk/PDF%20Fil...torfiction.pdf
Apologise if that doesn't work as a link, never done this before, but I found it interesting reading regarding eutectic and ingredients, and especially the corrosive action of silver on the soldering equipment as I struggle to keep my tips shiny despite doing what I am supposed to.
In the end I found solder at Farnell, a few to experiment with, there is so much choice I was losing the will to live, the only eutectic they sell is lead free with a high melting point, but I'm going to try it, I cannot find 63/37 tin/lead in the UK it's all in the US and it seems like a big - to me - import levy. So I have some Savbit and some cheap 60/40 as well.
Now to find some things to experiment on.
Temperature setting for soldering?Hide this!Advertise here!
How does OKi MFR soldering station set tip temperature? speakerguy79 Parts 0 25th March 2008 08:02 PM
Correct soldering temperature. Nordic Equipment & Tools 4 4th November 2007 07:43 PM
Soldering temperature for PCB? jholtz Digital Source 4 6th June 2005 09:18 AM
Opamp soldering temperature? Thunau Parts 10 17th September 2003 08:13 PM
Hakko soldering station temperature setting cards Saurav Parts 4 3rd September 2003 04:37 PM
