Equipment & Tools From test equipment to hand tools
Linkwitz Mods On Panasonic WM61A Mic
Old 23rd September 2013, 03:21 PM   #61
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by 1audio View Post
Unfortunately Panasonic exited the mike business, The WM61A is passing into history. Someone needs to find a successor. For flatness ST has some new MEMS mikes that are quite good with extended low frequency response. The SNR is very limited though. MEMS microphones - STMicroelectronics
Transound capsules are readily available. Some are a real step up in performance but not as small.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 24th September 2013, 07:02 PM   #62
1audio is offline 1audio  United States
The Transound elements look promising Transsound Electrets . Do you have experience with them? Which ones are preferred and which to avoid? The 12 mm capsules seem to have some shaping to the response.
Demian Martin
Product Design Services
Old 24th September 2013, 08:01 PM   #63
rikkitikkitavi is offline rikkitikkitavi
TS-60 looks awfully a lot like the old Panasonic WM-60 or WM-61 series.
listen! Can you hear that ...
Old 26th September 2013, 05:06 AM   #64
multi-volti is offline multi-volti  United States
multi-volti's Avatar
That TSB-165 looks cool...after reading how the small ones are noisy, I wished I could find larger ones...and it looks like it has three separate terminals, so surgery required to incorporate a source follower...the source appears to be separate from the ground.
Murray
Old 5th June 2016, 06:12 PM   #65
mandalore is offline mandalore  Serbia
Originally Posted by EUVL View Post
Yes you did (the 2 BJT circuit).
Thanks for the hints and comments.
Patrick
where is this circuit ? i have searched the diyaudio up and down but cant find it.
thanks
Old 7th June 2016, 11:07 AM   #66
Originally Posted by scott wurcer View Post
I don't see much new here. Did I show that little circuit with just two bipolars and capsule? It gets as much out of a WM61 as possible, "distortionless" output of volts and no added noise. I sort have gotten tired of explaining that you can't improve the noise except maybe by cutting away the baffle which grossly effects the flatness. People still put in a 2SK170 which makes the noise worse, the WM61 is just too small.
BTW electret microphones do not require an external bias, these guys are very confused. I also disclosed the feedback via the cut pin on the capsule on the micbuilders site years before this, didn't see the point of including it in the article because the capsule where the case is an input is hard to use. Zap or Eric could confirm that.
Pretty please ? I really can't find this circuit anywhere on diyaudio, I would really appreciate it if someone has it. Big thanks
Linkwitz Mods On Panasonic WM61A MicHide this!Advertise here!
Copyright ©1999-2017 diyAudio
