Equipment & Tools From test equipment to hand tools
Linkwitz Mods On Panasonic WM61A Mic
Old 26th June 2012, 02:09 PM   #41
lcsaszar is offline lcsaszar  Hungary
My observation is that some types of capsules need negative supply voltage related to the case. Also the output does not change when the supply voltage varies between 1.5V to 9V.
Old 26th June 2012, 02:54 PM   #42
teleman is offline teleman  Norway
Good to know! however, these bias configurations are particularly for the Panasonic WM61A mic capsules with the 2 & 3 wire Linkwitz mods.
I recently dissected one & found the middle pin (Gate) of the FET was bent to touch the casing (shorted). So in a non modded mic, both the Gate & the Source would be shorted? In the Linkwitz mod, cutting the trace disconnects the source pin from the Gate & casing? In the 2 wire mod you'd actually feed the -9V through a 10Kohm to the Sourcs to bias the FET!. Fig;3
Unlike a BJ Transistors, FET output don't change with increased voltage.This is one the intrinsic attributes of JFETs!
What I'm not sure about is whether grounding the Gate,directly,through a R or a Capacitor?
Old 26th June 2012, 03:28 PM   #43
The diaphragm is driving the gate (or rather the stator, one electrode of the capacitor). So the gate is "floating".
Old 26th June 2012, 03:31 PM   #44
Agreed! But, I've grounded the Gate directly to the signal ground & that works too! So I wonder what the advantages/diadvantages of these 3 grounding configurations?
Old 26th June 2012, 08:26 PM   #45
As you can see on the following picture from the link you provided, the gate is not accessible from outside:
http://www.openmusiclabs.com/wp/wp-c...ection_med.jpg
It is the center pin of the FET, touching the insulated pickup plate.
Old 26th June 2012, 09:08 PM   #46
Aah, now I get it...I thought it was shorted to the the casing! Thanks for pointing this out.
Old 30th June 2012, 08:41 AM   #47
Default ORIGINAL SPECIFICATION FOR UNMODDED WM61A
Here is the link to the spec given by Panasonic for the unmodded WM61A capsule.
Old 4th July 2012, 08:47 PM   #48
multi-volti is offline multi-volti  United States
multi-volti's Avatar
3M EMI copper foil tape is sold as having conductive adhesive. I think I read it has tiny copper spheres in the adhesive. I have used 'termite barrier' copper which is much thicker, for guitar shielding. The brand I used (can't recall, it's from a company in Maine that also makes 'too-thick-for-tape' flashing copper) has a non-conductive rubber-based adhesive.
Looking through a Digi-Key catalog, I see there are some ECM capsules that have gold-plated brass bodies, which would solder easily, with the same heat precaution.
I use a microscope to see the 'patient' ECM.
Now, my question -
I have three Kodak point&shoot digital cameras with usable video (2 are low-end HD) and horrible audio. One died and the the other two went 'Andy Warhol' - crazy colors. I found a service manual for the dead one on a Russian website and tore it apart with no intention of re-***'y.
Of the two semi-functional cameras, I got one running with correct colors with a couple whacks to the side (like an old TV), which has me wondering about ribbon cable connectors etc, internally.
I have never gotten a digital camera apart and back together previously. However, I took camera #3, got it apart without breaking anything (photoflash cap is discharged as well), and have the ECM hanging out now. It's tiny(maybe 4mm diam. 1.5 mm height?), 2-wire, and appears to be one of the gold-plated ones.
I will look again, but the SMT parts are so small on the circuit board where the ECM wires go that I doubt the resistors will have values on them (0402 or smaller usually do not).
So I am going to gamble that the service manual for the least expensive one that wore out & was disassembled has a similar bias circuit. I'll triple check what ASIC-type device the ECM feeds...I think they might not even be the same among the three cameras..but one for which I have a schematic has an 'isolated' 3V analog audio supply fed through a 22k resistor. There is a 1 uF (as best I can read the blurry schematic) X5R cap coupling audio and blocking DC at the (Altek?) audio processor.
So, assuming the camera I want to mod the mic on also has a 22k resistor feeding the drain, my feeling is adding a 22k source resistor probably has the lowest risk of running into headroom problems due to Vgs characteristics of the ECM jfet. OTOH, if you look at datasheets for jfets made for this app, many have very low Vgs(off), (and typically a 1 mA max drain current, BTW).
I considered drilling a hole where the mic sound hole was and running the wires outside to try different resistors or even an outboard modded mic, but I want to be able to get it back in the case (one time surgery) and through airport scans. I've not have good luck with wires hanging out of things...they tend to catch TSA attention.
Anyone agree or disagree with making Rs the same as the existing in-camera Rd? I want to minimize mods and poking around to anything past the ECM, as I'm already pushing my luck having gotten it apart without tearing any flex PC wiring etc.
I might try, if successful another one with an ECM I got off a toy Intel Voice Morpher. It had a larger capsule, roughly 8 mm diam mounted in a parabolic reflector!
The goal is make the camera audio usable. It currently is not. If I wanted higher quality and less portability I'd look at a separate audio recorder...and learn how to recombine audio & video...or buy a standalone video recorder that does the job adequately...but I'm not at that point yet.
Murray
Murray
Old 4th July 2012, 11:18 PM   #49
Sorry that I've given the wrong heading " Original specificaton for the unmodded WM61A" The link is actually for an ECM biasing/powering.
Old 8th July 2012, 09:23 AM   #50
I was able to cut the trace on the 3-4 mm diam. ECM (I had no choice but to unsolder the PCB side to give myself working room (1.5-2" leads)...I couldn't do it without the ability to hold the ECM on a flat surface. An Exacto blade was way too big! I used a really fine needle to scrape through the trace, while holding the body with fine tweezers.
The two ECM PCB traces are marked '+' and 'E'. I took E to mean earth...just to make some sense out of it. Now I have to find a resistor small enough...looks large under a microscope, but I realize I have significantly less than half the ECM diameter...so an 0603 resistor I can read the numbers on is relatively huge. The next couple sizes down are so small I'll probably need more than one resistor in case I lose some...I have lost 'duct-sized' parts before...I scraped solder mask off the areas I'll solder the resistor to...as far apart as I could to give me options for what size resistors I can find.
I'll be amazed if I pull this off...I mean get it back together still working...at least it's still promising no sudden-death failures have become evident yet.
Murray
Linkwitz Mods On Panasonic WM61A MicHide this!Advertise here!
Copyright ©1999-2017 diyAudio
