Equipment & Tools From test equipment to hand tools
My new bench power supply
Old 27th April 2003, 01:52 PM   #1
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Default My new bench power supply
For years and years I have been doing all kinds of experiments without the luxury of having a proper bench power supply. I always got by with small lead acid batteries or a transformer with some diodes and caps hanging off it. You know the story... Well the time had come to finally bite the bullet and build something useful. So here it is. First six pots (locking, 10 turn) are for 1.25 to 20v,1 amp all floating wrt to each other. Next one is 1.25 to 140v at 1 amp or less depending on output voltage. Last 2 pots are for + / - 1.25 to 40v 1 amp with a common earth. Also the full 40v at several amp unregulated is available. That sould be enough I think. The thing is mostly based on LM317 regs; the 140v output has a mosfet source follower that feeds the LM317 20 volts higher than whatever the output voltage is. Looks just like a cascode cct actually. As usual, made almost entirely of second hand junk. This is such a shock, me making somethng useful and almost tidy. Next thing you know I'll be digging the garden.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 27th April 2003, 02:10 PM   #2
Circlotron's Avatar
The guts. There are three 15 + 15 volt transformers hidden behind the aluminium heatsink bar.
Old 27th April 2003, 03:02 PM   #3
Da5id4Vz is offline Da5id4Vz  United States
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Digging in the garden!
SHHH!
Dont say that too loud, my wife might hear.
Its a great looking box. Will you add binding posts and metering in the future?
Old 27th April 2003, 05:07 PM   #4
davesaudio is offline davesaudio  Moldova
top pic:
what's on the left side middle (front to rear)?
varta lviv
Old 27th April 2003, 06:36 PM   #5
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
Circ you did a nice Job!!!!....the pots and knobs are worth a small fortune!!!....the p/s deserves some binding posts or a nice barrier strip
Old 28th April 2003, 11:32 AM   #6
Circlotron's Avatar
Default Spy satellite photo.
Originally posted by davesaudio
top pic:
I will eventually put some binding posts on the thing. It will probably go through a process of refinement. For example, I am already thinking of making the +/- 40v rails properly current limited and higher rating too.
Old 28th April 2003, 12:57 PM   #7
must be some new kind of mapingo(sic?) disk....
varta lviv
Old 28th April 2003, 03:29 PM   #8
Da5id4Vz's Avatar
Where did you snag all those vernier pots? Did you salvage some old test gear or do you have a greatr surpluss store?
Speaking of spy sattelites, please stay out of site while in the garden. Wives have resources you know.
My new bench power supplyHide this!Advertise here!
High-voltage bench power supply pmillett Power Supplies 56 19th March 2017 05:43 PM
Programmable Bench Power Supply? samsagaz Parts 1 22nd January 2008 02:21 AM
HV SS bench top power supply, advice needed panos29 Tubes / Valves 11 19th December 2006 07:06 AM
bench power supply jethari Parts 1 14th March 2003 05:31 PM
My bench power supply.. deepanger Solid State 71 18th February 2003 07:56 PM
Copyright ©1999-2017 diyAudio
