Equipment & Tools From test equipment to hand tools
Any suggestions on setting up a dedicated electronics work area at home ?
Old 16th September 2008, 07:51 AM   #21
Mooly's Avatar
Nearly posted a picture to that one Might have been getting a message from one of the moderators if I did.
Old 16th September 2008, 08:38 AM   #22
Geek is offline Geek
Geek's Avatar
Originally posted by 2pist
Just make it more organized than mine......
Do I spy me a B+K 1460 on your bench?
Old 16th September 2008, 02:53 PM   #23
2pist is offline 2pist  United States
Good eye! Bought it at a thrift store for $20. Works great.
Old 16th September 2008, 10:18 PM   #24
Geek's Avatar
They are great little scopes for audio work. Simple and cheap enough to fix too if we blow them up
(which I've done already)
I have a 1460 with a 3" screen and liked it enough that I got the dual-trace version, the 1470 with a 5" screen.
Old 17th September 2008, 12:41 AM   #25
Conrad Hoffman is offline Conrad Hoffman  United States
I've had a couple "curbside" kitchen tables in the basement for years. I stack the test equipment at the back, and work at the front. It just wasn't enough space, so I've got a carpenter building me a new workbench that will go the full length of the room, and will be deep enough to stack even the older very deep HP stuff, and still have room for projects in the front. I figure a combination of a super workbench, floor to ceiling bookshelves, and several of those large rolling wire storage racks, will finally get things under control. Pay attention to the other suggestions on ESD mats and grounding, a Variac, and build sturdy enough to hold up a small elephant. It doesn't take much older test equipment to add up to hundreds of pounds, not to mention that the tube equipment itself will add lots more. If you can make the space, dedicate specific areas for different tasks- in my case general construction and testing, metrology and calibration, then a place for all my ancient bridges and component test stuff. If you use a computer, make a place for that as well- mine will be tied to various pieces of test equipment via GPIB.
I may be barking up the wrong tree, but at least I'm barking!
Any suggestions on setting up a dedicated electronics work area at home ?Hide this!Advertise here!
chassis work in NYC area jayme Tubes / Valves 10 29th June 2006 02:16 PM
Home Entertainment 2003! Attn: San Francisco Bay area residents vsr123 Pass Labs 2 20th June 2003 04:39 AM
