Equipment & Tools From test equipment to hand tools
Workbench safety practices?
Old 3rd August 2008, 04:03 PM   #1
Stormrider is offline Stormrider  United States
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Default Workbench safety practices?
I worked in a electronics shop at my highschool and we had to follow OSHA guidelines for safety and that meant all workbenches had to have GFCI outlets installed. From what i remember even the outlets along the walls for the cleaning crew were GFCI's too.
My question is, how many of you have installed GFCI outlets at your workbench? I'm using a regular outlet at mine but I'm going to change that soon.
AJ
Old 3rd August 2008, 04:09 PM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
A GFCI does little good if you're servicing double insulated class 2 equipment.
Old 3rd August 2008, 04:24 PM   #3
I have RCBO (=gfci?) installed on all the power rings in the house, except the listening room.
regards Andrew T.
Old 3rd August 2008, 06:08 PM   #4
Stormrider's Avatar
True, you still have to use your head when working on all equipment. And really the only time i have something plugged in is when i'm testing, setting bias/dc offset and then i use alligator test leads. I can't think i've ever really had my hands inside a unit when it was plugged in. I have a portable oscope so the only test equipment i use that runs on AC power is a benchtop power supply and my computer which doubles as a signal generator.
RCBO is a circuit breaker version of the GFCI outlet. It goes in place of normal circuit breakers instead of the outlets and is probably the better solution of the two...
AJ
Workbench safety practices?Hide this!Advertise here!
Safety Practices, General and Ultra-High Voltage DrDeville Tubes / Valves 361 31st August 2017 11:00 PM
What's on your workbench ???? cnctooltek Equipment & Tools 308 22nd November 2011 10:31 PM
Safety Practices, General and Ultra-High Voltage DrDeville Everything Else 49 23rd September 2004 10:31 AM
Electronics Workbench 4 opamp sim bug. Circlotron Everything Else 0 12th April 2004 01:47 PM
