Equipment & Tools From test equipment to hand tools
Broken drill bit in chuck
Old 13th September 2007, 04:42 AM   #11
analog_guy is offline analog_guy  United States
Default Broken Drill Bit
If the drill bit is of reasonable diameter you might consider tightening up the chuck and drilling into the stub with a smaller diameter drill. Most steel bits are hardened only at the end, so the shank is reasonably soft and can be drilled with HS steel. If you can drill a hole in the shank stub, then you can either glue in a wire and pull out the stub or tap the hole, insert a screw of the appropriate diameter, and pull out the stub.
I have used an arc welder to stick a welding rod onto a broken spline and pull it out that way. Similar to the capacitor trick, but with a more controlled curent source.
Good luck.
JCM
Old 13th September 2007, 12:06 PM   #12
On Hiatus
SY's Avatar
Conrad: Three ways I can see. The third way is the best, bringing the barometer to the building superintendent and telling him that he can have that nice, shiny, new barometer if he'll tell me how tall the building is.
That welding idea is pretty slick. I'd have to find someone with much younger eyes and hands to do it for me.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th September 2007, 12:15 PM   #13
Conrad Hoffman is offline Conrad Hoffman  United States
One method I don't think I've seen published- the barometer probably has a nicely polished glass window to protect it. Move around until the sun is just next to the building and reflect it off the barometer window. Tilt the barometer until the reflected spot is on the base of the building. Now, move the spot up to the top of the building. Measure the angles of the barometer, and distance to the building, then calculate the height.
Old 13th September 2007, 09:24 PM   #14
bulgin is offline bulgin  South Africa
Default Broken Drillbit in Chuck
Hi gajanan
I'm afraid superglue will run everywhere you don't want it to go. Other than the neat tranny trick, shoving it out with a piece of shimstock sounds a better idea. How's about using the blade from an NT cutter to scrape it out? Recommended NT cutter model # A300. Is the chuck's collar captive?
IF the chuck was ally, you could have tried leaving it in some nitric acid for an hour or two. The acid will act quickly on the steel drillbit, leaving the ally not too chewed.
bulgin
Old 14th September 2007, 04:19 AM   #15
gmphadte is offline gmphadte  India
Using superglue would definitely be a risky process, as it will stick to unwanted places.
I have canada balsam, as a substitute to superglue, in mind, if cap discharge welding does not work. I will have to experiment on another drill bit to try its needs.
Presently, the chuck is not with me and it is Ganesh Chaturthi Festivities from tomorrow. It belongs to another institute few kms away.
The building height issue...
May be a gravity difference measurement between bottom and top should be easier, assuming that the gravitational force reduces as u go higher.
Have fun
Gajanan Phadte
Broken drill bit in chuckHide this!Advertise here!
To drill or not to drill? (a VPI turntable) m.parigi Analogue Source 5 6th January 2006 02:32 AM
Craig Anderton appearing at Chuck Levins Da5id4Vz Everything Else 0 8th September 2003 07:49 PM
Drill aluminium Edwin Dorre Everything Else 30 14th May 2003 03:46 PM
DeWalt DW991 chuck removal ultrachrome The Lounge 1 1st April 2003 02:57 AM
should I chuck my P-mount TT? leadbelly Analogue Source 10 15th March 2003 10:22 PM
Copyright ©1999-2017 diyAudio
